The NEWEST official E36 OT Thread!! - Page 125 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-10-2016, 11:36 PM
E36 Phantom's Avatar
I Am The Machine
Originally Posted by drivinfaster View Post
color me cofused, chad, but other than the odo and speedo being "off" due to larger tires, what would regearing the diffs provide ??
not real familiar with off road stuffs, but thought larger tires were "better"...
Bigger overall diameter is better as it gets your axles and diffs farther from obstacles. Also, bigger sidewalls are better, as they provide more ability for the tires to conform the terrain and obstacles when aired down. But they extra weight and diameter of that combination causes you to lose a ton of power. Shorter gearing gets that power back for on road driving, as well as providing a bit more advantage for climbing over obstacles.
Originally Posted by EnserioJose View Post
Hey guys! Oh just hanging out here in the snowy midwest. Trying to stay on top of a rusty XJ, an 18 yo e36, a house, 2.6 acres of land, work projects, an upcoming wedding... so typical life, right
How have you two been? Any more Randys added to the baby stable? Any progress on the m shoe front?
Sounds about right.
We had one in May, he's almost 8months now. No more Randys shall henceforth be added to the stable. General craziness both around the house and at work.
Sent from my VK810 4G using Tapatalk
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 01-11-2016, 03:06 AM
Dio///M's Avatar
Dio///M Dio///M is offline
Mein Auto: E93,E36 M3,E39,E46
Farewell to the Legendary Mr David Bowie.
His fine work and iconic presence influenced many over 4 decades,.. his early departure will leave a large empty space in the music world.
Old 01-11-2016, 03:25 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Just ordered floating hardwood flooring. Anyone have tips for install? I'm planning on doing some YouTube searches.
Turbo Build Here
Old 01-11-2016, 05:00 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
matt,
duct tape the padding together
watch your orientation in regard to sunlight (expansion concerns) so plan accordingly if there are large windows/sunlight coming through to the flooring,
don't run too tight to the wall but pack your joints tightly together (get the tool for flooring as well, it's about 10 bucks or so iirc) and watch your ends. use a scrap piece to run interference with the tool as to not damage the joints.
plan your layout. watch for pipes through the floor (if radiant heaters) and whenever possible, stagger the seams as to not run "square" with each other.
sorta like this...
______________________________l___________________ ________
________l_____________________________________l___ ________
_________________l________________________________ ____l
as opposed to this...
____________________l_________________________l___ __________
____________________l_________________________l___ ___________
measure thrice, cut once.
do you have a compound mitre saw?? a jigsaw and hole saw bits would probably be beneficial as well. and i liked to use scrap pieces of cardboard for edges around doors, cabinets, and such to get an idea as to how the cuts will go.
chisels, too.
all sorts of tips and tricks regarding the trim, as well. notching the back for curves and such.
get some scrap lumber, like 1x3's, and cheapy 1/4 round to get an idea of what cuts are necessary if you aren't sure. it's much cheaper to cut a scrap piece than the higher end trim pieces, even with some relatively inexpensive composite pieces.
also pay attention to the visible finished ends. on composite type matertials a dull blade will rip the finish.
make sure all the peaks, points, burrs, and things that would pop up from the floor are made flush. depending on the subfloor you may need to use leveler (several thin layers are better than 1 heavy application), and make sure the floor itself is sound. fix any wiggles, bounces, and squeaks prior to laying the floor down.
there's probably lots more, but this and the vids will sorta give you a good direction to go.
if you have a mud room that will wind up getting a lot of traffic, i would suggest doing that room first. it's smaller, is supposed to get dirty, and will give you a pretty good taste for the larger scale rooms that need to be prettier.
good luck with it!!
df
Old 01-11-2016, 11:53 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Roll Tide!
That is all....carry on.
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
Amateur Extra ham radio operator KO4AXN, see you on 40 meters!
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 01-12-2016, 05:56 AM
Needs Boost
Mein Auto: Red Sled
Thanks DF! I'll update with pictures, will probably start next weekend.
Also, dropped the E30 off at Monroe Muffler for a new exhauat, yikes. The current exhaust is getting louder by the day, the muffler is very rusted.
Oem replacement is too expensive so well see how they do.
Turbo Build Here
Old 01-12-2016, 06:35 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Oh God... OH GOD...
http://washingtondc.craigslist.org/n...396927506.html
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 01-12-2016, 06:47 AM
Dio///M's Avatar
Molested gains a new meaning with that ^
Old 01-12-2016, 07:45 AM
I Am The Machine
Originally Posted by hnaz View Post
Meh. That's not even close to molested. It's just lambo doors and a cheap stereo deck. It would take half a day to go back to stock with no lasting effects.
// Chad //
You're a derbanana
Old 01-12-2016, 08:01 AM
hnaz's Avatar
BMW CCA Member
HAHAHA! My thoughts exactly!!
By the way, I found an ad on Facebook East Coast Classifieds for what I was talking about with my E39:
My Previous Work:
Old 01-12-2016, 09:57 AM
dc_wright's Avatar
^This^
That's not anywhere close to "Head Twista" molestation.
Condition of the SMG pump and whether or not it had any of the rod bearing recalls done would be far more concern to me.
Old 01-12-2016, 10:12 AM
Dio///M's Avatar
True,...regular maintenance and repair bills are king....but over the years of my buying experience I've been convinced that the cared ones are usually nearest to stock.
On the subject of 'headtwista 's' it would be funny to see a few examples posted for a good laugh...
Old 01-12-2016, 12:26 PM
bliger7gz's Avatar
bliger7gz bliger7gz is offline
Mein Auto: 1994 BMW 325is
FINALLY
Found the M3 struts I needed for the Koni inserts, been looking for months. I found a couple nearby but the sellers wanted too much, iirc 200 or more. One place in TX had them for $150 shipped, decided to wait and it paid off.
These were the parts I needed picked up from MD. A friend of mine went there yesterday and picked them up for me on his way back. I paid $75 for these.
I'm getting close to doing a rear bushings and will likely get the Koni STR.T for the rear as well, one shock is showing signs of a small leak. For the front I'll do FCAB and these, should make a nice improvement.
1994 BMW 325is "Feldt" w/Turner Motorsports chip
Old 01-12-2016, 12:47 PM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
I've got a pair of STR.T rear shocks for an e36. One is NIB, the other has a couple thousand miles on it.
The shot heard 'round the world.
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
Old 01-12-2016, 01:07 PM
LukasW's Avatar
LukasW LukasW is offline
Mein Auto: 98' 328i
Whatve you guys done with your E36 audio? I double din would be cool, but really spendy. A pair of speaker in my front door are rattling. I want crisp bass and clear audio
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 01-12-2016, 03:59 PM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
Hey guys looking for some advice I'm at an "Impasse". The m3 body I have is officially garbage passenger side rocker is shot most of the section under the rockers is rusted out near the jack pads as well as rust in the floor boards. I rent from a body shop owner so,I'm sure I could get the rust repaired but, my guess is the bill would be 2-5k for a legit repair without paint due to unibody structure and wonderful jack point repair. So the question....do I just scrap the shell and try to find a caged/roller e36 shell? Or, do I sell off the 8k I have in bolt on parts and pickup a muscle car like a 66 chevelle as a project. Something like the one below. Sorry for the rant..I'm just losing motivation and kinda pissed/upset that I paid a good chunk of change for something that I pretty much have to part out and start over.Click image for larger version
Lots of junk.
Old 01-12-2016, 04:11 PM
bliger7gz's Avatar
I put a Sony head unit when I got my car since it came with no radio. At the time the rear speakers were blown and had a Infinity Basslink subwoofer already installed.
Then I replaced the front and rear speakers with Kicker speakers, liked the improvement. Door speakers are still good. I wanted to go OEM on the head unit so I found a CD43 unit, which many report is an upgrade over the stock units C33 and C43.
I don't have a musician's ear but sound is good. And since the car already had a Subwoofer on the back it sounds even better.
Finding a CD43 head unit might be as expensive as a double din unit, if you go with an aftermarket unit get one that has red backlight on the buttons so it blends in. Little hint, the BMW and Rover versions of the CD43 are both the same just different logo on the faceplate.
This is the before
Sony head unit at night
And this is now
CD43 at night
Dwonda went with different brand for speakers (bsw I believe) but I think same head unit as me and he loved it, apart from an iPod integration unit I don't know what else he did.
Old 01-12-2016, 04:32 PM
olivers_bmw olivers_bmw is offline
NCC BMWCCA member
Mein Auto: E36 and e34
Originally Posted by bimmer claus View Post
Hey guys looking for some advice I'm at an "Impasse". The m3 body I have is officially garbage passenger side rocker is shot most of the section under the rockers is rusted out near the jack pads as well as rust in the floor boards. I rent from a body shop owner so,I'm sure I could get the rust repaired but, my guess is the bill would be 2-5k for a legit repair without paint due to unibody structure and wonderful jack point repair. So the question....do I just scrap the shell and try to find a caged/roller e36 shell? Or, do I sell off the 8k I have in bolt on parts and pickup a muscle car like a 66 chevelle as a project. Something like the one below. Sorry for the rant..I'm just losing motivation and kinda pissed/upset that I paid a good chunk of change for something that I pretty much have to part out and start over.Attachment 545904
We just scraped/shelled a 97 e36 for the same reasons, rocker/frame rust. Drivetrain has been pulled and ready for the solid donor car. 92 e36 sedan surface rust that was an automatic is up next. Engine out and suspension going into 94 vert and will have another shell ready for its next life.
Depends on finding a "deal" on a muscle car shell, good ones can be expensive.
Old 01-12-2016, 04:40 PM
Santa
Mein Auto: 95 M3
How much was the donor car you picked up. Thanks for the opinion!
Lots of junk.
Old 01-12-2016, 05:36 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
I remember when you got that car and how clean it appeared to be. Sucks it turned out to be a rust bucket . If you are tried of dealing with rust, an old muscle is a terrible idea. I think you should take some time and find a real rust free shell and swap everything over to that. Also you should scrap off the old under coating and rust prof the fcuk out of the new shell. You will be a lot happier with your e36 when you have one that is rust free and you know it is going to stay rust free.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 01-12-2016, 05:41 PM
Santa
Mein Auto: 95 M3
It was clean until I started poking around haha. I'll just see if I can pick up a caged shell or just a plain roller at some point here. Good news is the motor/tranny are already pulled out of the rust bucket so, I'll just finish stripping her down sell the motor and continue with the s54 e36 direction. Thanks for the input! Just what I needed to here.
Lots of junk.
Old 01-13-2016, 10:21 AM
Brake_L8's Avatar
Brake_L8 Brake_L8 is offline
Ambitious But Rubbish
Mein Auto: 97 M3 | 96 328iC
Man, sucks about the rust. I once bought an E36 in similar condition, while potentially hungover or still feeling the effects of the night before. Joey was there. It was awful. Thankfully, I was able to put it back on Craigslist and get my money back after a few days. I ran the VIN last year and it's somehow still alive and registered in Tennessee now.
On a more positive note, I bought a truck last night!
2011 FX4 with the Coyote 5.0 V8, 4x4, and 47k miles. Has the "Max Tow" package and is rated at 9,300 lbs. The bed is already spray-lined and I want to swap out the current bed cover for one that can lock. Bonus tow-ability points include the 3.73 rear end, electronically locking rear diff, built-in brake controller, "productivity screen" between the gauges to track trailer mileage and store up to 10 different trailer profiles, and the extended range 36 gallon fuel tank (vs. stock 26 gallon).
- Jake
Now:
11 Ford F-150 FX4 | 97 BMW M3 | 06 BMW M3 Convertible
Then:
87 BMW 325e | 91 BMW 535i | 96 BMW 328i | 95 BMW 325i |95 Mazda Miata | 13 Ford Focus ST | 09 BMW 128i | 00 Pontiac Firebird | 05 GMC Yukon Denali | 96 BMW 328iC
Old 01-13-2016, 10:43 AM
hnaz's Avatar
BMW CCA Member
Holy cow! That truck is amazing!!!
My Previous Work:
Old 01-13-2016, 10:51 AM
hnaz's Avatar
BMW CCA Member
Dirt cheap because of the rust. It really was THAT bad. Only thing usable was the drivetrain and engine. The White Car is going to be dismantled and suspension parts transferred to Frank's (olivers bmw) convertible.
The White Car would be a good rent-a-race shell to setup, but it is an autotragic. At least the engine is good. Tranny is junk aka coffee table/rat trap.
My Previous Work:
Old 01-13-2016, 02:40 PM
Needs Boost
Mein Auto: Red Sled
Monroe Muffler wanted over $500 to replace the oem rear muffler on yhe e30. They wanted almost $400 to do a custom rear muffler. [Trying to save money]
So needless to say I ordered an OEM rear muffler for $210 with shipping and will put it on myself.
If I had a lift I would have just built the exhaust myself.
Turbo Build Here
damn you chad!
