Tire pressure monitor - Bimmerfest - BMW Forums
Old 01-21-2020, 07:19 PM
philipnjones philipnjones is offline
Mein Auto: 2002 525iT
The tire pressure monitor light keeps coming on in my 2007 3.0 Z4. I keep trying to reset it, but nothing works. I checked the pressure in all four tires. All OK. What am I doing wrong?
Old 01-21-2020, 09:15 PM
keeton keeton is offline
Mein Auto: '07 3.0si
1. Drive a few miles and if you are sure that the pressures are OK, the system may reset itself.
2. One (or more) of your valve stem sensors have gone bad.
Old 01-22-2020, 10:09 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
The valve stem pressure sensors are battery powered and, as mentioned, after 12-13 years the battery in one or more has possibly died. The batteries cannot be replaced so the valve has to be replaced - replace all four as the others will fail soon.
Old 01-22-2020, 08:32 PM
You are 100% correct. My tire guy concluded the same thing you concluded. Maybe you should go into the business.
Thanks.
Old 01-24-2020, 11:43 AM
rsutoratosu rsutoratosu is offline
Mein Auto: Z4
Its likely battery as mentioned above. Anyone found new sensors thats not sitting on shelf with fresh battery?
