I was changing oil the other day on my wife's Z4 and I noticed this bolt:
It's a 13mm head, I tried to tighten it but it was pretty hard to turn, so I started trying to lookup some information on what it is. I don't want to torque it down inside the aluminum block and strip something. Any advice?
This is a guess but I vaguely recall seeing such a bolt used too assist in the adjustment of the alternator, and it was meant to stick out just like that. My advise is not to touch it for the moment, it probably is just fine.
Likely used to adjust the alternator to “line” up into the proper position for its pulley to be parallel with everything else when v belt installed.
If you look closely at what it “pushes” against... you will see that if you loosen off the bolt securing the alternator in position, you would be able to adjust the alternator backwards if you tighten “that bolt”... alternatively... backing off on “that bolt” in question will allow the alternator to move slightly forward.
I’d just leave it alone as suggested as it would have been a factory adjustment at time of assembly.
That bolt has nothing to do with alternator. Just replaced mine & there are 3 bolts holding it on & that isn’t one of them. The idler pulley is next to it & that is held one by 1 bolt that goes through the center. It looks like it is a bolt to hold part of the aluminum bracket it does through. It’s not supposed to be like it is - someone probably removed it & cross threaded it at one point.
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
