HowTo: Pics - Replace Convertible Rear Speakers - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 05-25-2009, 08:45 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Just replaced the rear speaker in my '96 328ic ragtop and thought I'd share the info on how to do it with less expensive aftermarket speakers. The factory speakers are custom made and fit into a housing in the side panels in the rear seat area. Found that a set of Pioneer TS-G1042R speakers fit very nicely.
To remove the side panels slide them forward toward the front of the car and they will pop loose, exposing the speaker assembly.
Unplug the connector first by squeezing on the release tabs and carefully working it off.
Remove the speaker assembly by removing the four screws that hold it into the car body. (Be careful of the one on the bottom screws hidden by foam.)
Remove the old speakers by carefully breaking off the 4 plastic tabs and prying around the speaker diameter to loosen them from the housing. Clip the speaker wires as close to the speaker as possible to save as much wire as you can to make the new connection.
Fit the new speakers and mark the points to drill.
Use sheet metal screws to mount the new speakers.
Strip and solder the wires to make the connection.
Replace the speakers in the car body.
Turn on your audio and crank it up to see if you have any buzzes or rattles. If you do, check tightness of the speaker mounting screws and housing screws. Fill any gaps between the speaker assy housing and the body with cork, rubber, or other filler until you've got the offending noises fixed.
Reintall the side panels by sliding them toward the back of the car.
You're done!
ID:	186900   Click image for larger version
ID:	186901   Click image for larger version
ID:	186902   Click image for larger version
ID:	186903   Click image for larger version
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 05-25-2009, 08:31 PM
MrGrahamE36 MrGrahamE36 is offline
Mein Auto:
looks awesome
Old 07-05-2009, 04:10 AM
flukeskywalker flukeskywalker is offline
Mein Auto:
id you find there was much difference between the speakers? more bass :-) or just clearer? I am planning a similar mod, but for the sake of 40.00 is it really worth it?
Old 07-05-2009, 11:07 AM
theoriginalgiga theoriginalgiga is offline
Mein Auto: 2008 750LI
Sir, you're my hero, let me know if you do the front as speakers are my project here in the coming month.
Awesome pictures, love what you've done, I did something similar with my corolla and though I was hoping for an easy swapout i figured I'd have to do something like this.
Again, thanks!
Old 07-05-2009, 04:58 PM
dc_wright's Avatar
To FlukeSkyWalker: My old rear speakers were so badly rotted and fuzzy sounding I had cranked the fader to use only the front speaker set. So on that basis the new speakers are much better! Can't really pass any info on compared to good OEM. Sorry!
To theoriginalgiga: My front speakers seem to still be good and my door panels don't have any squeaks or rattles (rare on older BMWs) so until it sound like any of the front speakers have broken I'm not screwing around with em!
Old 07-08-2009, 08:29 AM
fastfinger fastfinger is offline
Mein Auto: 1996 328 convertible
Alpine 5 1/4" rear convertible speakers
Outstanding post!
I didn't want to go through the hassle of breaking the original speaker mount.. and since my car is an older 1996- the original speakers were toast. The convertible rear side speakers are the easiest ones to get at of any car I ever owned. so I yanked them and with some self tapping screws, just inserted Alpine 5 1/4" in the holes and they worked great. a all the books said I had to use 4" !!! Next project is to trial fit some Alpine 6 1/2" component speakers set nto the front kickpanel and door to upgrade the original speakers... hope they fit as well.
Old 07-08-2009, 06:30 PM
dc_wright's Avatar
With some thought and some work there is plenty of room for bigger speakers if you shop around and buy the right ones. I thought about doing something bigger but I'm trying to keep the car as near stock as possible unless the cost is just outrageous. Guess it's an OCD kind of thing. The BMW OEM speakers unfortunately fall into the outrageous category.
Old 07-09-2009, 05:53 PM
kosmocat71 kosmocat71 is offline
Mein Auto:
Amazing-I just got some used MB Quart speakers for real cheap to replace my broken front kick panel speakers--!
I have been searching for PICS and someone that did the rear speakers-!! Way to go -!!
Old 07-30-2009, 10:51 AM
Hellawut??
Mein Auto: who knows?
there was a guy who put low profile 12's in the feet area on a bmw..... looked flucking sweet
-Franklyn
Old 07-30-2009, 11:55 AM
HyphE36's Avatar
HyphE36 HyphE36 is offline
Search Button Upper Right
Mein Auto: E36 95 325IS Black/Black
Nicely done DC
I wish I had the money to mess around with the speakers and what not in my car, 95 325is. It has a horrid sound stage that I want to change, most of the speakers point to horrible places, like feet haha, but I don't have the money for new speakers and materials at the moment
Looking for a nice classic 2002, 1972-75 preferred
. SOLD
MEMBER OF THE MOST EXCLUSIVE SECRET CLUB ON THE 'FEST
Old 09-01-2009, 11:02 PM
shredspillers shredspillers is offline
Mein Auto: 1994 e36 convertible
e36 conv. total system upgrade
I have a 94' 325i conv. I just wanted to have a better sounding system. When I started out I just wanted to speand like $1,200 but when I went to the car audio store they wanted lile $1,000 just to install everything I had.
HU JVC AVX44 wasnt iphone compatable so I got the new
JVC AVX77
Focal 130kp front stage upgraded to
Focal 165KRX2 6.5" front stage
Focal 130cvx rear fill
Focal 27KX 11" sub
Alpine PDX 4.100 4ch. amp
Alpine PDX 1.600 mono amp
Dynamat
Streetwire ZN7 interconnects
Monster 304 XLN Speaker Cable (4-Conductor)
I did all the work myself this was my 1st stereo install. I took my time on this install and learned everything as I went. I had some help from internet. I 1st put the 5 1/4in. Focal 130kp. But I was wanting 6.5in. then I got the new Focal 165KRX2 they are actually 6 3/4in. component speakers. don't get me wrong the Focal 130kp sounded awesome. But The KRX2 are much better sounding speakers here in what I did I built amp rack in the trunk
ID:	199510   Click image for larger version
ID:	199511   Click image for larger version
ID:	199512   Click image for larger version
Name:	WOOFER SKI PASS.jpg
ID:	199513   Click image for larger version
Old 09-02-2009, 10:45 AM
dgraypost79 dgraypost79 is offline
Mein Auto: BMW 318i
Thats a great system right there... dynamat is the ****!! Good work..
Old 09-02-2009, 07:16 PM
HyphE36's Avatar
Nice work Shred
and.... Welcome to the 'Fest!
You should start your own thread on that, I'm sure it will have interest.
. SOLD
Old 09-02-2009, 07:22 PM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
I got the same pioneer speakers except in the 4in and put them in the doors. They sound pretty good. I'm still having trouble finding a way to keep them in place.
Old 09-02-2009, 11:50 PM
thanks alot it. was alot of work. its still a work in progress.
Next is to put my Focal 130kp in for rear fill. Need to figure out
how and what I need to do to get them installed in the rear panel.
so thats my next project. I have a few ideas.
Thanks again !!
Old 09-03-2009, 12:48 PM
synenergy52's Avatar
synenergy52 synenergy52 is offline
Send a message via AIM to synenergy52
Mein Auto: 2016 Lexus Hybrid
Thanks for the sweet write-up!!
Complete BMW E46 Cooling System Guide
Shop at FCPEuro.com and use code MangoFCP5 at checkout for 5% off your order!
Old 05-16-2011, 04:14 PM
steveziv steveziv is offline
Mein Auto: 318i
Worked like a charm, thanks!
Old 11-26-2011, 11:07 AM
JTHiggins JTHiggins is offline
Mein Auto: 1999 323i Vert
Im having a hard time getting the 4in speaker out of the OEM assembly. Also, do you think its possible to replace the tweeter? I'm concerned about keeping the old tweeter in there, as Im sure it sounds like garbage.
Old 11-26-2011, 05:37 PM
dc_wright's Avatar
It's some patience and some work to get the OEM 4 inchers out. They're pressed in pretty tight and you have to break off the 4 locking tabs on the speaker to even have a chance to get it to move.
If you use the speakers I did they're two way and have the tweeter integral to them, so you only hook up to the new speaker. I just left the old tweeter in place since it wasn't in the way or hurting anything.
Good luck!
Old 08-13-2013, 04:50 PM
Fitzz Fitzz is offline
Mein Auto: 1997 328i
Panel...
I guess my panels have never been taken off before but, mine are not budging, thoughts? Just got her and the rear speakers need replaced.
Old 08-13-2013, 05:24 PM
dc_wright's Avatar
Its the center panel insert that slides forward and I believe you need to have the door open for it to move. They do fit pretty snugly but they eventually slide.
Old 08-14-2013, 08:27 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Mine were really stuck as well. I ended up pushing/prying/pulling and broke two of the clips that hold the panel on.
When I re installed them, the broken clip didn't seem to make a big difference, but I'm sure its a bit looser now. My 318 'vert is now in the hands of someone else.
The doors do need to be open to remove them. I also found the the plastic/vinyl was stuck together. You might try, gently, trying to unstick them. This is how I broke the clip-
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 08-14-2013, 11:37 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
JVC AVX77
Focal 27KX 11" sub
Dynamat
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 08-14-2013, 04:15 PM
chillwill13555's Avatar
chillwill13555 chillwill13555 is offline
chillwill
Mein Auto: bmw e46
nice dc just did my rear speakers put 5 1/4 in rear 200watts sounds sweet lol thanks for the info cuz
Old 11-04-2013, 02:43 PM
doddsr doddsr is offline
Mein Auto: 1996 328iC
I just replaced my rear speakers with some 4" Polk speakers, and my stereo is an Alpine I had installed two years ago. Speaker install was very easy - the problem is they sound like crap! Of course they sounded good in the store. What did I do wrong? Could it be my amp?
