Spark plug replacement X1 28i E84 N20 - Bimmerfest - BMW Forums
Old 03-01-2019, 02:36 PM
swcurry swcurry is offline
Mein Auto: X1 x28i
I was going to change my plugs for the first time and i came across a problem with the torque. I bought the NGK Laser Iridium plugs but the NGK website has the torque for a aluminum head at 10.8 to 14.5 foot pounds. The BWM torque is said to be 23 + or - 3 which would equal 16.96 foot pounds at 23 and 14.75 foot pounds at 20 which is still over the max on the NGK Spec. I'm not sure what torque to use.
Old 03-01-2019, 03:11 PM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
i think i did the minimum recommended by BMW
Old 03-01-2019, 03:23 PM
Mein Auto: X1 x28i
The minimum for BMW is just over the max for NGK so I was thinking to do the 14.5 which is the max for the plug. Thanks for the quick reply..
Old 03-02-2019, 12:56 PM
wvadam wvadam is offline
Mein Auto: X1 2.0L xdrive
how many miles/km are you replacing them at?
Old 03-02-2019, 01:50 PM
Mein Auto: X1 x28i
82k
Old 03-03-2019, 07:56 AM
0w40X1 0w40X1 is offline
Mein Auto: 2014 X1 s28i Msport
How has car run lately? You loosing MPG, power, or just think it's about time?
Old 03-03-2019, 01:53 PM
Mein Auto: X1 x28i
It's running good but i was loosing a little MPG. I was getting around 27.3 combined and i was getting around 28 a few months ago. I drive about 65 miles a day mostly hwy. I replace them today and reset the MPG so we'll see if it improves. The original plugs looked to be in good shape but i did notice a little build up on the electrode which closes the gap. I fired it up and it sounds great. I didn't use any anti-seizing compound because i read on the NGK website its not recommended. I did used some electrical grease.
Old 03-03-2019, 02:12 PM
You bring up a very good point about the electrical grease!
People are saying again and again not to use anti-seize but then what if it were to seize? They say the plugs are plated and wont corrode but you could say that about most fasteners. Maybe it is not recommended because certain types don't get along well with aluminum like copper. Maybe it hardens over time and when you remove the plug, the material could drop into the cylinder? But I can't see a small amount of electrical grease being a problem. I just did my plugs with no A-S but didn't think about just using a dab of grease.
Similar Threads
Misfire after spark plug change BabyUnicornTaco X5 E70 (2007 - 2013) 3 09-02-2018 09:50 PM
Spark Plug Replacement BabyUnicornTaco X5 E70 (2007 - 2013) 7 08-07-2018 03:04 PM
BMW Service Spark plug Question vbcgy F10 / F11 (2011 - 2016) 3 08-02-2018 03:43 PM
Feel stupid. Could not remove spark plug coil & boot EconoBox E39 (1997 - 2003) 12 03-07-2018 12:55 PM
Feel stupid. Could not remove spark plug coil & boot EconoBox E46 (1999 - 2006) 15 03-07-2018 10:32 AM
