timing chain tensioner - Bimmerfest - BMW Forums
View Poll Results: change the tensioner at 100k miles
Yes because it will help 2 100.00%
Yes yes and change guides and chain as well 0 0%
No because another part causes the failure 0 0%
No because it doesn't wear 0 0%
Voters: 2. You may not vote on this poll
Old 03-10-2019, 10:18 PM
wvadam wvadam is offline
Mein Auto: X1 2.0L xdrive
Timing chain tensioner: is it worth replacing as preventative for high mileage N20?
I personally feel that the guides cheap thin plastic breaks and causes the chain to oscillate and cause the destruction. Is it possible to change the guides without a mechanics 12hrs of labor?
It also seems like the oilpump chain can fail first (in that case you hear the whine and have to replace everything anyways) so that is outside this discussion because the noise will tell you what to do.
Edit: Notice in the picture I do see broken guides but not broken chain. Has anyone seen otherwise?
ID:	843413   Click image for larger version
Name:	broken timing chain guide.jpg
Old 03-11-2019, 09:26 AM
0w40X1 0w40X1 is offline
Mein Auto: 2014 X1 s28i Msport
If i SAW ANY TENSIONER PIECES, I'd put a new chain and guides
The chain could already be worn and or stretched.
Old 03-11-2019, 10:21 AM
mreric mreric is offline
Mein Auto: 2015 BMW X1 Xdrive E84
there is a TSB from bmw that shows to replace these guides and chain for vehicle made before 03/2013 . i think if the vehicle is made before 03/2013 then is a good idea to do so
Old 03-11-2019, 12:03 PM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
I changed it at low mileage on my X4 with the N20 motor. Surely there is a reason why BMW has used at least three different models of this part. And I assume "newer is better." There are some visual differences and the spring on the latest version also seemed stronger. Anyway, here is a link to my DIY on the X4 forum.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 03-11-2019, 12:22 PM
thank you for the link, seem the tensioner seem to be an easy replacement . or you made it look easy !....
might consider it. seem to be cheap insurance.
Old 03-11-2019, 06:18 PM
So When the 2014's came out in about April 2013 they have new improved guide?
My 2014 X1 s28i was built approx may 23rd, 2013.
Similar Threads
Replaced my timing chain guide tensioner... but should I have? MSporting E39 (1997 - 2003) 76 03-31-2019 09:50 AM
99 540 M62tu timing chain tensioner oil leak Panel beater E39 (1997 - 2003) 8 10-15-2018 10:48 AM
