E71 x6 m50d lag and strange knock sound when kickdown - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X6 F16 (2015 - Current)
The all new 2015 BMW X6 is the second generation luxury cross over. BMW referes to the X6 as a Sports Activity Coupe (SAC) as it combines the attributes of an SUV (high ground clearance, xDrive and all-weather ability) with the stance, styling and roof line shape of a coupe. The F16 BMW X6 is build side by side with the F15 X5 at BMW's BMW's Spartanburg, SC plant. Read all about the second generation BMW X6 here!
Old 01-15-2019, 03:33 AM
Alex.grk Alex.grk is offline
Mein Auto:
Hi guys, I'm having some issues with my x6. I tried to overtake a car and when pressed the kickdown it had a lag and a knock noise.. After the power came back and had no issues while driving. After couple of miles the engine management light came on(limited power). After turning off the engine and on again it disappeared. Checked the fault codes and than reset them but it still does that when I accelerate hard. Thanks.
OBD2 - pending:
P0401 - Exhaust Gas Recirculation "A" Flow Insufficient Detected
P0101 - Mass or Volume Air Flow "A" Circuit Range/Performance
Engine:
48F6
4868
40D4 - EGR Actuator Position Control
4501 - Exhaust Gas Recirculation- Negative Deviation or Air Mass too High
4521 - Boost Pressure Actuator ***8218; Regulation Pressure too High
3FF1 - Air Flow Meter
Instrument cluster:
A566
Dynamic management:
6435
Central electronics:
E2C7
Central module (in driver's footwell) (FRM):
9CC5 - Driver's side mirror heating faulty
Infotainment system:
E1CF - No message, receiver CCC/RAD2/RAD1, transmitter instrument panel
Telephone:
A900
A8F9
ECU info obtained with Carista 374099 for iOS:
VIN: WBAFH82010LK44704
Engine
Part #: 8573235
Hardware #: 00 (hex)
Coding index: 02 (hex)
Diagnostic index: 16
Variant index: 22617
Manufacture date: 2012-09-11
Supplier ID: 08 (hex)
Message catalog version: 8.2.48
Functional software version: 65.87.67
Operating system version: 3.3.1
Fault codes:
48F6 Manufacturer-specific code
Transmission
Part #: 7641033
Hardware #: 55 (hex)
Coding index: 08 (hex)
Diagnostic index: 4640
Variant index: 20815
Manufacture date: 2008-05-01
Supplier ID: 47 (hex)
Message catalog version: 0.38.5
Functional software version: 233.68.0
Operating system version: 4.1.0
[No fault codes]
Transmission
Part #: 7643768
Hardware #: 10 (hex)
Coding index: 00 (hex)
Diagnostic index: 4656
Variant index: 22594
Manufacture date: 2012-05-24
Supplier ID: 60 (hex)
Message catalog version: 0.36.136
Functional software version: 6.0.0
Operating system version: 4.2.1
[No fault codes]
Fuel pump
Part #: 7276046
Hardware #: 06 (hex)
Coding index: 13 (hex)
Diagnostic index: 4112
Variant index: 22084
Manufacture date: 2005-08-04
Supplier ID: 07 (hex)
Message catalog version: 0.19.3
Functional software version: 6.0.3
Operating system version: 4.2.3
[No fault codes]
Heater & air conditioning
Part #: 9310449
Hardware #: 08 (hex)
Diagnostic index: 3376
Variant index: 20040
Manufacture date: 2012-10-05
Supplier ID: 21 (hex)
Message catalog version: 0.35.13
Functional software version: 5.33.255
Operating system version: 3.3.60
[No fault codes]
Rear heater & A/C
[ECU not present]
Auxiliary heater
[ECU not present]
Traction/stability control
Part #: 6864696
Coding index: 05 (hex)
Diagnostic index: 3013
Variant index: 20548
Manufacture date: 2011-09-14
Message catalog version: 0.35.0
Functional software version: 44.76.0
Operating system version: 0.0.0
[No fault codes]
Airbags
Part #: 9240083
Hardware #: 03 (hex)
Coding index: 26 (hex)
Diagnostic index: 3233
Variant index: 20043
Manufacture date: 2012-08-16
Message catalog version: 0.31.70
Functional software version: 34.10.8
Operating system version: 3.40.10
[No fault codes]
Center safety module
[ECU not present]
Left B-pillar safety module
[ECU not present]
[ECU not present]
Right B-pillar safety module
[ECU not present]
[ECU not present]
Instrument cluster
Part #: 9231324
Hardware #: 12 (hex)
Coding index: 03 (hex)
Diagnostic index: 3312
Variant index: 20051
Manufacture date: 2012-09-09
Supplier ID: 10 (hex)
Message catalog version: 0.32.212
Functional software version: 179.65.65
Operating system version: 3.16.1
[No fault codes]
Dynamic management
Part #: 6857403
Hardware #: 04 (hex)
Coding index: 06 (hex)
Diagnostic index: 4048
Variant index: 21589
Manufacture date: 2012-07-19
Supplier ID: 24 (hex)
Message catalog version: 0.32.197
Functional software version: 44.53.2
[No fault codes]
Power steering
[ECU not present]
Tire pressure monitor
[ECU not present]
Adaptive cruise control
[ECU not present]
Adaptive steering system
[ECU not present]
Steering column
[ECU not present]
Active roll stabilization
Part #: 6797919
Diagnostic index: 594
Variant index: 20570
Manufacture date: 2012-08-20
Message catalog version: 0.31.224
Functional software version: 9.0.0
Operating system version: 5.6.0
[No fault codes]
Electronic damper control (EDC)
Part #: 6785396
Hardware #: 34 (hex)
Diagnostic index: 706
Variant index: 20038
Manufacture date: 2012-08-28
Message catalog version: 0.20.235
Functional software version: 8.0.0
Operating system version: 5.4.7
[No fault codes]
Damper control (front left)
Part #: 6785379
Hardware #: 01 (hex)
Coding index: 04 (hex)
Diagnostic index: 3072
Variant index: 20812
Manufacture date: 2012-07-26
Supplier ID: 56 (hex)
Message catalog version: 0.17.163
Functional software version: 7.6.6
Operating system version: 5.4.5
[No fault codes]
Damper control (front right)
Part #: 6785380
Manufacture date: 2012-07-09
Message catalog version: 0.17.164
[No fault codes]
Damper control (rear left)
Part #: 6785377
Manufacture date: 2012-08-09
Message catalog version: 0.17.165
[No fault codes]
Damper control (rear right)
Part #: 6785378
Manufacture date: 2012-07-23
Message catalog version: 0.17.166
[No fault codes]
Auto-leveling suspension
Part #: 6793163
Hardware #: 14 (hex)
Diagnostic index: 689
Variant index: 16720
Manufacture date: 2012-08-22
Supplier ID: 43 (hex)
Message catalog version: 0.32.251
Functional software version: 6.45.0
Operating system version: 3.2.1
[No fault codes]
Parking brake
Part #: 6850289
Hardware #: 05 (hex)
Diagnostic index: 3344
Variant index: 20549
Manufacture date: 2012-07-22
Message catalog version: 0.23.150
Functional software version: 5.60.0
Operating system version: 3.10.0
[No fault codes]
Trailer
[ECU not present]
Car access system (CAS)
Part #: 9389116
Hardware #: C4 (hex)
Coding index: 09 (hex)
Diagnostic index: 1696
Variant index: 21313
Manufacture date: 2012-09-03
Supplier ID: 04 (hex)
Message catalog version: 0.0.0
Functional software version: 2.8.1
Operating system version: 3.3.0
[No fault codes]
Alarm
[ECU not present]
Alarm sensors
[ECU not present]
Parking sensors
Part #: 9249451
Coding index: 01 (hex)
Diagnostic index: 4720
Variant index: 22352
Manufacture date: 2012-10-04
Supplier ID: 11 (hex)
Message catalog version: 0.32.3
Functional software version: 4.4.1
[No fault codes]
Central electronics
Part #: 9334611
Hardware #: 19 (hex)
Diagnostic index: 4240
Variant index: 21848
Manufacture date: 2009-09-02
Supplier ID: 61 (hex)
Message catalog version: 0.37.252
Functional software version: 4.32.13
[No fault codes]
Center console switches
[ECU not present]
Light switch
[ECU not present]
Adaptive headlights
[ECU not present]
High beam assist
[ECU not present]
Part #: 6801293
Coding index: 33 (hex)
Diagnostic index: 3680
Variant index: 22085
Manufacture date: 2012-10-03
Supplier ID: 09 (hex)
Message catalog version: 0.19.9
Functional software version: 18.20.0
Operating system version: 4.20.0
Fault codes:
9CC5 Driver's side mirror heating faulty
Junction box (passenger) (JBBF)
Part #: 9292708
Coding index: 40 (hex)
Diagnostic index: 3536
Variant index: 22341
Manufacture date: 2011-02-10
Message catalog version: 0.30.41
Functional software version: 2.84.0
[No fault codes]
Keyless ignition
[ECU not present]
Micro power supply
[ECU not present]
Convertible top
[ECU not present]
Center roof module
Part #: 9225868
Diagnostic index: 3440
Variant index: 20049
Manufacture date: 2012-10-15
Supplier ID: 03 (hex)
Message catalog version: 0.19.8
Functional software version: 5.1.9
Operating system version: 4.0.1
[No fault codes]
Sliding roof
[ECU not present]
Rear hatch
Part #: 7335274
Coding index: 14 (hex)
Variant index: 21329
Manufacture date: 2007-11-29
Message catalog version: 0.20.205
Functional software version: 2.4.0
[No fault codes]
Rain/light sensor
[ECU not present]
Front left door
[ECU not present]
Front right door
[ECU not present]
Driver's seat
[ECU not present]
Front passenger's seat
[ECU not present]
Active backrest (driver)
[ECU not present]
Active backrest (passenger)
[ECU not present]
Emergency response unit
[ECU not present]
Audio amplifier
Part #: 6835041
Hardware #: D5 (hex)
Coding index: 10 (hex)
Diagnostic index: 4976
Variant index: 22869
Manufacture date: 2017-08-21
Message catalog version: 0.23.132
Functional software version: 16.11.0
Operating system version: 3.3.3
[No fault codes]
Sound system
Part #: 9285383
Hardware #: D2 (hex)
Diagnostic index: 4992
Variant index: 22868
Manufacture date: 2012-08-18
Supplier ID: 49 (hex)
Functional software version: 12.7.1
[No fault codes]
CD changer
[ECU not present]
Infotainment display
Part #: 9273189
Diagnostic index: 4352
Variant index: 22097
Manufacture date: 2012-10-13
Supplier ID: 20 (hex)
Functional software version: 8.15.23
Operating system version: 6.0.7
[No fault codes]
Infotainment system
Part #: 9273157
Coding index: 1A (hex)
Diagnostic index: 4336
Variant index: 21845
[No fault codes]
Infotainment (rear)
[ECU not present]
Bluetooth
[ECU not present]
Part #: 9289580
Hardware #: D4 (hex)
Diagnostic index: 4528
Variant index: 22593
Supplier ID: 53 (hex)
Message catalog version: 0.38.13
Functional software version: 199.73.64
[No fault codes]
Infotainment display (rear)
[ECU not present]
Navigation
[ECU not present]
Radio
[ECU not present]
Digital radio
[ECU not present]
Telephone
Part #: 9257165
Hardware #: 07 (hex)
Diagnostic index: 4608
Variant index: 22851
Manufacture date: 2012-09-05
Message catalog version: 0.35.230
Functional software version: 3.4.31
Operating system version: 255.255.255
[No fault codes]
Tuner
[ECU not present]
Satellite radio
[ECU not present]
Video
[ECU not present]
Multimedia changer
[ECU not present]
Headphone interface
[ECU not present]
Heads-up display
[ECU not present]
Flexible bus interface
Part #: 9257166
Diagnostic index: 4624
Variant index: 22615
Message catalog version: 0.31.96
Functional software version: 3.4.5
Operating system version: 4.2.2
[No fault codes]
CAN network gateway
Part #: 9273168
Diagnostic index: 4320
Variant index: 22083
[No fault codes]
CAN network gateway
[ECU not present]
CAN network gateway
[ECU not present]
All-round vision camera
Part #: 9291386
Diagnostic index: 4736
Variant index: 22362
Manufacture date: 2008-04-27
Message catalog version: 0.33.158
Functional software version: 211.64.64
[No fault codes]
Lane-change system
[ECU not present]
Rear axle slip angle control
[ECU not present]
Video switch
[ECU not present]
Electric motor-driven reel (left)
[ECU not present]
Electric motor-driven reel (right)
[ECU not present]
Night view
[ECU not present]
Camera-based driver assist system
[ECU not present]
Gear selector switch
Part #: 9228827
Diagnostic index: 3632
Variant index: 20552
Manufacture date: 2008-07-24
Supplier ID: 02 (hex)
Message catalog version: 0.31.81
Functional software version: 64.50.0
[No fault codes]
Rear-compartment controller
[ECU not present]
Rear compartment display 2
[ECU not present]
Rear seat (driver's side)
[ECU not present]
Rear seat (passenger's side)
[ECU not present]
Parking/steering assist
[ECU not present]
Vertical Dynamics Management
[ECU not present]
Right headlight
[ECU not present]
Rear differential lock
Part #: 7595848
Diagnostic index: 4080
Variant index: 21587
Manufacture date: 2012-09-06
Message catalog version: 0.27.193
Functional software version: 0.36.0
Operating system version: 4.10.0
[No fault codes]
Treble bass extender (TBX)
[ECU not present]
VVT bank 1 (cylinders 1 to 4)
[ECU not present]
VVT bank 2 (cylinders 5 to ***x1f60e;
[ECU not present]
Security module 1
[ECU not present]
Security module 2
[ECU not present]
Unknown ECU
[ECU not present]
Unknown ECU
Part #: 9180490
Hardware #: 40 (hex)
Diagnostic index: 0
Variant index: 22345
Functional software version: 0.0.0
[No fault codes]
E71 x6 M50d 2013
Last edited by Alex.grk; 01-15-2019 at 03:36 AM. Reason: I did not specify the exact model
Old 01-17-2019, 06:39 AM
Mein Auto:
Performed a egr and dpf delete(software only) and problem still persists! Help!
