Is my OFHG leaking ? - Bimmerfest - BMW Forums
Old 03-30-2019, 08:03 PM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
See attached images. OFHG ? I know it's a common leak on the E9x.
ID:	845991   Click image for larger version
Not even sure if -40 degrees is cold anymore ?
Old 03-30-2019, 10:55 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
I'm no mechanic, but that looks pretty clean.
I think if it was leaking, you would see worse.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 03-31-2019, 03:03 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
+1.
Wipe the film off and monitor.
If someone else does your oil changes ...
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 03-31-2019, 02:21 PM
Engine needs a wash anyways, after the filthy winter driving. Will give it a good cleaning and then monitor
Old 03-31-2019, 06:22 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
if anything id say the cap is leaking not the filter housing itself. but as a bmw tech i wouldnt sell anything to a customer at this point in time.
Similar Threads
N73 motor leaking coolant from BACK of motor mws 7 Series - E65 / E66 (2002 - 2008) 5 05-02-2019 06:47 PM
Oil leaking Ericyin 7 Series - E65 / E66 (2002 - 2008) 3 03-11-2019 01:34 PM
2006 335i ATF leaking excessively mclarry01 E90/E91/E92/E93 (2006 - 2013) 1 11-27-2018 12:00 PM
New water + engine heater inlet coolant pipe leaking chimacc E39 (1997 - 2003) 2 10-17-2018 11:08 AM
