Downsides to an xDrive? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 03-25-2019, 04:13 PM
lmacmil lmacmil is offline
Mein Auto: 2006 BMW Z4 3.0si
I'm thinking about a 228i or 230i convertible to replace my 2006 Z4. It would be a 7-8 month car. Since I am in the upper midwest, pretty much all the 2-series are xDrive which I don't need for April to November driving.
Other than weight, mechanical complexity and mileage (not a big concern since it doesn't get that many miles in a season), are there any reasons to steer clear of an xDrive model?
2006 3.0 Si
Old 03-25-2019, 05:44 PM
Sportstick's Avatar
Sportstick Sportstick is offline
Still Stickin' It!
Mein Auto: '15 228i Track Pkg/6MT
Exclamation
Duller steering feel, more tendency to understeer, both from the additional weight specifically over the front.
2015 228i 6MT
VO over Oyster Dakota/Brushed Aluminum/Fiery Orange IP Trim Wrap
Handling Package/M2 Lower Control Arms/KCDesign Strut Brace
Tech/Cold/Premium/Lighting/Driver Assistance Pkgs
Xpel Clear Paint Film/Opticoat Pro
BBS Wheels/PS4S Tires
MPerformance Black Kidney Grilles/Decklid Spoiler
Coding by Alex
2018 330i GT - 100% Stock
Old 03-25-2019, 05:53 PM
terryn's Avatar
terryn terryn is offline
Mein Auto: 2016 M235xi
More weight for sure. Also, its not as sophisticated as the Audi Quattro. The BMW X Drive has also jumped and jerked for me when backing and turning. Just doesn't feel good. On the other hand, I am on my third X Drive. I think it really helps in snow and allows me to run performance snow tires rather than having to go to a traditional snow tire. X Drive will also improve your 0-60 a little if that matters.
2019 M240xi Estoril Blue Metallic, Black Dakota Leather, Premium Pkg, HK Stereo, Adaptive LED Lights, Black Kidney Grilles, High Kick Rear CF Spoiler, Lightweight front lip, non run flat mixed performance tires, BMW M Performance Exhaust, Dinmann Carbon Fiber Rear Diffuser
Prior: 2016 M235xi, 2013 328xi Sport
Old 03-25-2019, 06:07 PM
Sportstick's Avatar
Still Stickin' It!
I believe you are absolutely correct about being able to have less effective winter tires with XDrive and still get the vehicle going, which is convenient. However, when it comes to stopping/turning, perhaps when needed quickly, XDrive adds nothing and the loss of tire capability may result in a very unfortunate outcome. Hope that doesn't happen and good luck!
As to 0-60, I believe any system which splits torque to 4 wheels instead of 2 only is helpful when the amount of powertrain output exceeds the ability of 2 tires to maintain traction while accelerating WOT. This might be more likely with a 235 or 240, such as yours, but seems very unlikely with a 228 or 230, particularly with automatic trans.
2015 228i 6MT
Coding by Alex
Old 03-25-2019, 06:36 PM
Autoputzer Autoputzer is offline
You need the rolling diameter (and therefore tread depths) to be very close to identical to prevent pre-mature xDrive transfer case clutch wear. With a staggered wheel and tire set-up (back wheels and tires wider than the front), xDrive is a no-win situation. The back tires will wear faster, increasing the difference in rolling diameters. With a square set-up, you can rotate your tires to keep the tread depths very close (almost identical) on all four tires.
I think the xDrive hardware adds about 200 pounds on smaller BMW's.
Nobody wants xDrive's here in Floriduh. Even the new BMW SUV's on dealer lots are about 75% sDrive's. We got xDrive because we're eventually moving north where it snows and we'll be living on the top of a hill.
Old 03-25-2019, 07:07 PM
I was in Fla in Jan/Feb and there were lots of RWD 228i convertibles for sale. I may have to go back if/when I decide to pull the trigger.
2006 3.0 Si
Old 03-25-2019, 07:49 PM
There's a lot of convertibles here. Northerners move here and the first car they buy here is a convertible. They're great in the winter, early spring, and late fall. The rest of the time it's MAX AC with the top up.
Florida cars can have a lot of sunlight damage, though. Dark paint colors eventually burn to a crisp if parked outside in the daytime, and no amount of wax can stop it.
I'm not a convertible guy, but I must have a sunroof.
Old 03-25-2019, 08:19 PM
terryn's Avatar
you are correct about about the turning issue. I learned this in my 3-series trying to run Pirelli A/S as snow tires with X Drive. They were downright scary in intersections trying to turn in the snow. It was like being in a toboggan. Bad snow tires results in tracking in a straight line. Michelin Pilot Alpin PA4s are the performance winter tires I use. In up to about 6 inches they do well enough handling and steering in the snow, and the X Drive gives that extra traction assist. Agree that X Drive alone won't be enough, you still need a reasonable winter tire but the X Drive gives you a little more choice of that tire IMO.
Old 03-29-2019, 07:59 AM
imtjm imtjm is offline
Mein Auto: 328ix sdn; M240ix cpe
why don't you need xdrive from april-november? by saying something like that, you do not understand the purpose behind xdrive.
Old 03-29-2019, 08:03 AM
huh? this makes no sense.
Old 03-29-2019, 12:54 PM
We get little or no snow from April to November. I have been driving 2WD cars year around for 50+ years without a problem and since any convertible will not be driven in the winter, I don't need AWD.
2006 3.0 Si
Old 04-02-2019, 12:27 PM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
... are there any reasons to steer clear of an xDrive model?
Frankly, knowing what I know now and didn't know in 2010 ... I would steer clear of it for a very simple reason - it is soooo much easier to get a limited slip diff on rear axle if that is the only one putting down the power. And with LSD on the rear ... heaven. Trust me on that one. I went from open diff to LSD and that has got to be be a TOP #1 modification to make you giggle at lawful speeds on a public road. Well, that and a good stereo - those twin exhaust pipes with performance exhaust.
Good luck with your quest!
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 04-11-2019, 12:28 PM
again, your comment is based on misinformation/lack of information about what xdrive is and isn't and what is for or isn't for. moreover, just because you have been driving 2wd cars for 50+ years is meaningless regarding the purpose of xdrive. The comment is also like saying well I've been driving without a seatbelt, airbags, antilock brakes, etc for 50+ years without a problem.
Old 04-11-2019, 03:05 PM
That sounds like a lot of car salesman talk to me.
I've gone 45 years in between my (dumb and selectable) 4WD and Frau Putzer's (smart, full-time) AWD. I was fine. Four of my 2WD cars had limited slip or locking differentials though. LSD or LD keeps 2WD... 2WD, instead of 1WD and with the one tire being the one on ice, sand, mud, etc.
I have it on high authority that a Porsche Cayenne can outrun a Carrara 2S in the rain at Barber Motor Sports Park. But, that's only when you're going over 100 MPH in the rain.
Here's a good reason to avoid xDrive if you don't need it...
https://www.bimmerfest.com/forums/sh...1#post12968731
Old 04-12-2019, 07:31 AM
Sportstick's Avatar
Still Stickin' It!
I think there is no question that the same vehicle on the same dedicated winter tires will be more capable on snow/ice with XDrive. Many people judge the value of XDrive by this single attribute and don't consider as much the lack of contribution to stopping/turning. Against the specific benefit, all the downsides should be measured, both in winter, as well as carrying around that mass and cost all year long.
2015 228i 6MT
Coding by Alex
Old 04-12-2019, 08:55 AM
Orca Orca is offline
Mein Auto: 2011 BMW 528i
Depends on how long you gonna keep your car. So perhaps consider cost of maintenance/repairs?
That's the reason I chose RWD F10 BMW 5-series. I got mine used and i'm planning to keep it as long as it runs. even though I live in Toronto, Canada and drive quite a bit in a winter (road trips for skiing etc)
As others mentioned already, RWD performs adequately on good winter tires and I personally didn't have any issues with driving my RWD F10 during snowstorms here in Ontario/Quebec.
Old 04-12-2019, 09:36 AM
Yikes! I remember getting axle boots replaced on my Mercury Topaz in the early 90s for about $100 a side.
2006 3.0 Si
Old 04-12-2019, 11:31 AM
what salesman talk? if you say xdrive is for winter only, then that is a false statement. xdrive assists in forward momentum of any slippery condition, and there are slippery conditions which do not include snow and ice.
don't know what this has anytyhing to do with xdrive. or are you trying to make the point that awd outruns rwd? at least that is what is being implied here, although two entirely different vehicles, says nothing about the shoes being worn, etc.
a reason is because a cv boot may crack? cv boots crack regardless of if you have xdrive or not.
Old 04-12-2019, 01:05 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
xDrive does nothing to effect the stopping distance. However, if you know how to drive in poor conditions, there are noticeable turning benefits to AWD.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 04-12-2019, 06:42 PM
southcoastguy southcoastguy is offline
Mein Auto: 328xi
Consumers Reports did a test with 4-wheel drive vehicles and turning/stopping.Using winter tires made all the difference, not 4-wheel drive.
Old 04-12-2019, 06:50 PM
LSD's, LD's, and modern computer-controlled traction control do what most people outside of the snow belt need, without adding $2k to the MSRP, 200 pounds to the curb weight, and potentially thousands of dollars in repair costs.
The outer boots on the front axle on FWD and AWD vehicles are usually the first ones to tear. That's because they not only rotate with the driveshaft, but bend with the turning of the wheels.
Old 04-12-2019, 06:53 PM
If a car has enough volume and it it's cheap enough to be a popular hooptie, the aftermarket produces replacement driveshafts. My '92 Nissan Sentra SE-R was a rare enough car that the only source for driveshafts was Nissan. I think one back in 1995 was about $400, and that was from a dealership that did a lot of mail-order business with about a 35% discount over the parts counter price.
My plan with Frau Putzer's X3 xDrive 30i is to do a preventative "boot job" at about 85k miles.
Old 04-13-2019, 05:21 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
My issues are initial extra cost, extra weight and maintenance costs. I live in the metro DC area so we rarely get a bad snow storm. When we do I use the wifeís accord thatís equipped with Vredstein Quatrac 5 tires.
Old 04-13-2019, 05:54 AM
Mein Auto: 328xi
BMW dealers in the Northeast sell a majority of cars with x-drive. Everyone here has this belief that without 4-wheel drive you will be stuck in the winter.
Old 04-16-2019, 11:34 AM
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Mein Auto: 2011 BMW 335xi
Apart from the points ppl already mentioned, itís less fun to drive than an RWD one! As long as you know how to drive and have good winter tires, AWD is not a necessity for snow driving. It HELPS but not important. Iíve driven a Ford Crown Vic and a Mercedes C class in the snow with no issues.
Here in Canada 95% of BMWs are xDrive. My 2011 335i is xDrive as well and when I took it down to Arizona last year and got it serviced there, the service writer is surprised that itís xDrive as they donít exist in Arizona. Itís available as an option that no one buys.
Similar Threads
Complete 2018 Model Year BMW Pricing and Ordering Guides - All Models tim330i Ask-A-BMW-Dealer 7 10-09-2018 12:15 PM
NEW! F3X Carbon Fiber M Sport Steering Wheels by ECS Tuning ECSTuning F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 2 07-24-2018 10:08 PM
NEW! ECS Carbon Fiber M Sport Steering Wheel! | Intro Pricing $449.95 with Free Ship ECSTuning Site Sponsors & Bimmerfest Group Buys 1 07-24-2018 12:19 PM
Give our 2-series the Steering Wheel it deserves! NEW Carbon Fiber M Sport ECSTuning F22 / F23 2 Series (2014 - Current) 8 07-24-2018 12:18 PM
