F020 (F02x, F03x, F08x) F30 cruise control retrofit coding problem - Bimmerfest - BMW Forums
Old 02-18-2019, 07:19 AM
waleedmango waleedmango is offline
Mein Auto:
Hi,
My friend have a 2013 320i with plain steering wheel (no cruise control, LIM or audio controls at all)
I bought a multifunction steering wheel (32306854753) with cruise controls, installed and coded:
VO 249, 540
but i get this message:
No FP could be generated from FA "". [C002]
Not all elements of FA were found in the FA2FP: SALAPA 540 [72]
So I tried VO 544 instead of 540 and restarted the car.
Now all the buttons working but once I hit the road and press the master cruise switch or the + - button I get a message on the dash " Cruise Control Failure " and once the car restarted it goes off.
So I removed the SALAPA 544 and coded the car again, the SET button acts now as a LIM button and the limiter works.
E-Sys version : 3.27.1
PSdZData version : 4.15.23
I need your help I want the cruise control to wok.
My friend went back to his town and will be back in a few days
What shall I do next ?
ID:	840397   Click image for larger version
ID:	840399   Click image for larger version
ID:	840401   Click image for larger version
ID:	840403   Click image for larger version
Old 02-22-2019, 11:22 AM
Mein Auto:
I bought a used instrument cluster that support $544A and will try to coded and deal with the tampering LED later
Old 02-23-2019, 04:12 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
You have to delete old VIN in kombi first otherwise you will not be able to inject CAFD and code it (you will get an WDBI_CPS error).
CU Oliver
BMW F30 330e Hybrid 2016 in tansanit blue, cohibabrown for every day (10/2019 G20 330e in tansanit 2 blue, all in )
Jaguar XK8 Cabrio, 2006, black, 20" for the summer time
BMW M4 F83 Cabrio competition in black for the wife
Old 02-23-2019, 04:36 AM
Mein Auto:
Thanks milkyway for your input
I will do all the necessary eeprom work before installing the cluster
Old 03-14-2019, 04:53 PM
Mein Auto:
Dear Milkyway,
I used to R270+ programmer to read the eeprom and this is what I got.
Please help me indicate which values I need to FF to clear the old vin
is it the one in row 580 and 650 ?
the chip is 35160WT
I will also incluse the full BIN file
I need to FF the VIN only because the mileage is lower than my original KOMBI
ID:	843883   Click image for larger version
Old 03-15-2019, 04:27 AM
Mein Auto:
Do I have to FF the whole row of 580 and 680 ?
Or only these values :
35 41 30 39 36 30 34
What's the next step in E-SYS ?
Old 03-17-2019, 09:14 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
File with edeleted VIN (2 x short, 1x long) is attached. Mileage is the old one!
CU Oliver
Old 03-17-2019, 03:30 PM
Mein Auto:
Thank you Milkyway
I have flashed your file to the eeprom successfully
I will post once installed and coded with E-sys
Thanks again
Old 03-25-2019, 11:39 PM
Mein Auto:
Hi,
I'm planning to install and code the cluster this week.
Can somebody tell me please if I need to inject CAFD or just add $544A cruise control and FA code the whole car.
What should I do in E-Sys
Old 03-26-2019, 06:33 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Injection is for missing or corrupt CAFD. Do you have either?
Old 03-26-2019, 09:26 PM
Mein Auto:
No
Old 03-26-2019, 09:29 PM
Mein Auto:
Nope, but I read everywhere for retrofitting a different cluster they do CAFD injection.
The car didn't come originally with cruise control switches and cluster.
I'm installing a Virginized used cluster, Do I just need to install it and do VO code for KOMBI, is that it ?
Old 03-27-2019, 08:33 PM
Mein Auto:
I installed the cluster today and added VO 544 for cruise control but I got error on BKOMBI coding.
I tried many times until I clicked on (Detect CAF for SWE) and didn't find the same i-level so I choose a random one with newer date then the BKOMBI coded successfully
After that it's showing red and blue mark on the BKOMBI folder
The cluster works fine except for the red dot ( my cluster mileage is lower than the actual mileage, the VIN is erased from eeprom)
Anyway the cruise control lights is working but when I hit the road and try to set the speed I get error " cruise control can't be activated "
I'm stuck now . I NEED YOUR HELP
Old 03-28-2019, 04:36 AM
weebyx weebyx is offline
Mein Auto: BMW 320d F30 2018
I installed a brand new 6WB and got the red dot after coding. Cleared all errors with ISTA and coded again, red dot was gone.
Regarding cruise control, maybe your FEM has to old SW for the kombi. There are other posts where they say after installing a new kombi, cruise does not work anymore because FEM is to old.
Just some points to look into, I have not experience with CC retrofit myself.
/Weebyx
Old 03-28-2019, 05:40 PM
Mein Auto:
Here is the error codes I get
Do I need to flash FEM_GW, do I need to flash all ECUs because this ECU will be newer I-step than the others ?
Can I downgrade the BKOMBI to match the rest of the car's ECUs ?
The car is 2013
The BKOMBI is from 2014 car
I found a guide in how to flash it but i'm afraid If i flash it then it won't communicate with other ECUs
ID:	845755   Click image for larger version
Old 03-29-2019, 03:30 AM
The car is 2013
I dont know if you can downgrade, it should be possible to manually change TAL, but that is not something I have any experience with.
Flashing is always tricky if not done right. I would say the correct way, is to update the cars I-Step, and in that case also update KOMBI to that I-Step. That way the ECU's are on same level and everything should work. Is BKOMBI correct HW/Partnumber for your car, just newer ?
But, be aware that full flash requires power supply and a lot of knowledge so you dont destroy stuff.
Old 03-29-2019, 05:00 PM
Mein Auto:
Thank you very much,
BKOMBI is one of the alternative part numbers that fit the car, it's a used unit removed from 4 series car
I'm waiting for the full PSdZdata to download then I will give it a try
Old 03-31-2019, 06:50 AM
milkyway's Avatar
Mein Auto: F10 M5
Hello!
As posted in PN you have to update your FEM_GW so it's also on a newer i-level. If Kombi and Gateway has a difference in i-level from 3 years or more the cruise control will not work. They speak both the langauge but not the same accent.
CU Oliver
Old 03-31-2019, 07:17 AM
Mein Auto:
Originally Posted by milkyway View Post
Hello!
CU Oliver
What about the Dependencies of FEM_GW ? Do I have to update them after FEM_GW ?
Is it possible to set the KOMBI on a lower i-level eg. 2015- (less than 3 years gap) to avoid the hassle of updating FEM_GW
Old 05-31-2019, 12:44 AM
Mein Auto:
Thanks milkyway
I flashed FEM_GW to the latest i-step and I got the cruise control working finally
I'm really thankful for your help and support
Old 05-31-2019, 12:45 AM
Mein Auto:
Thanks milkyway
Old 06-18-2019, 12:32 PM
t0mip0 t0mip0 is offline
Mein Auto:
Hello there i have a 316d with plain steering wheel (no cruise control, LIM or audio controls at all)
VO 249, 544
I need your help I want the cruise control to work.
DO I REALLY NEED TO CHANGE THE KOMBI ?
Old 06-18-2019, 01:00 PM
Mein Auto:
That's exactly what happened with me, you need to change the cluster (KOMBI)
Buy a new one or a used one (PITA to erase the old VIN)
Old 06-26-2019, 10:30 AM
Mein Auto:
ok i desided to just have normal buttons on the left side of the steering wheel just LIM nothing alse. But know even the lim funkcion doenst work what did i do wrong.
LP
Similar Threads
Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets Almaretto BMW Coding and Programming 506 12-04-2019 07:34 AM
BMW 545i hick-ups at cruise control floridiaan75 E60 / E61 (2004 - 2010) 5 01-08-2019 11:06 AM
F020 (F02x, F03x, F08x) Problems with coding Cruise Control zzzZZZzzz BMW Coding and Programming 1 09-02-2018 10:41 PM
2018 X5 Adaptie Cruise Control Milam X5 F15 (2014 - 2017) 2 07-02-2018 04:22 PM
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
