Misfire in 5th gear - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-02-2018, 09:50 AM
KrankE46 KrankE46 is offline
Mein Auto: E46 325XI
Misfire in 5th gear
Got a little issue I need help figuring out.
2004 325XI - 250,000 miles
I have a misfire which causes rough running and lose of HP which pops the CEL telling me "Misfire in cylinder #2". This usually happens when I'm cruising @ 3,500 in 5th gear. I can drive all over town without issues, but when I get on the hwy, within a mile or two I have the issue. I do not have the issue in 4th gear at the same rpm's.
I replaced the spark plug and ignition coil, no change.
Question - does the CPU have a different map it goes into when in 5th gear? If so can this be the issue?
Question - how likely is it to be the CPU or a broken wire?
Old 01-02-2018, 10:43 AM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
The car at 3500 rpm 5th gear constant speed needs more horsepower than at 3500 rpm 4th gear. This is due to the air flow resistance.
If there are performance differences between cylinders, they are more likely to show at high power output.
Swap injectors between cylinders, see if the misfire moves. And check compression.
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 01-03-2018, 05:43 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
Misfire in 5th gear
Itís not a broken wire. That would cause a constant problem. How old is the fuel pump? When was the fuel filter last changed? A soft failing fuel pump can cause some odd issues.
Old 01-03-2018, 07:29 AM
Fuel pump and filter replaced in the last 6 months.
Sent from my SM-G920T using Bimmerfest mobile app
Old 01-04-2018, 05:00 AM
What brand of pump and filter? It does matter.
misfire, misfire in 5th gear
