OBD1 E36 running rough / rich; no CEL - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-12-2018, 05:08 PM
zainathan zainathan is offline
New to Bimmer's
Mein Auto: 1995 BMW 325i M50
Bought a VERY rought e36 a while ago and had it running decent for a bit until an injector lost its cap/oring and i decided to get all new injectors, as id had injector issues earlier on.
Got the car back together and it starts and runs, but idles rough and spits a little gas out of the exhaust. Im not using a battery rated for this car (battery out of a 2.2 2000 camry) and was wondering if that could be the issue? Or if anyone has any other suggestions im very open, but basically out of money.
thanks!!
1995 BMW 325i Sedan (E36) Manual Trans
Old 02-12-2018, 06:48 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Battery will make no difference in running quality unless the alternator isn't working. My guess is the replacement injectors you got are wrong for the car.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 02-12-2018, 07:12 PM
New to Bimmer's
i forgot to mention that the car begins its idle kind of rough and takes a minute to find a solid idle. Could i be looking at a vacuum leak? would that cause the imbalance thats making the car run rich?
Old 02-13-2018, 02:24 PM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
How long was the car down for? Gas could be crap. WEre the injectors rebuilt or just used units? Last fuel Filter change?
I would look for a vacuum leak as a start and go from there. How did you know you lost an o ring and a pintle cap?
Old 02-14-2018, 08:21 PM
New to Bimmer's
When i pulled the fuel rail, the injector cap/ oring fell into my hands. Im thinking its a vacuum leak of some sort. I recently pulled apart the ICV but it was giving me the same symptoms before pulling the injectors/ icv (obviously was worse pre injector replacement) The injectors are reman. The gas shouldnt be too bad, its been sitting maybe 2-3 months (or could it?) as for the fuel filter im not sure.
Old 02-15-2018, 10:20 PM
Stallion13 Stallion13 is offline
Mein Auto: 1995 BMW 325is
Sounds like you may have found the issue but maybe it is worth checking the O2 sensor?
Old 02-16-2018, 01:06 AM
New to Bimmer's
i definitely can give it a look. However, I have no CEL. when the injector was bad i got a 1253 (injector 3 bad) so i figure it would throw a 1212 or a 1221 code if the o2 was bad.
Old 02-16-2018, 02:26 AM
OBD I is not as sensitive as OBD II. I would continue on the vacuum search.
Old 02-24-2018, 03:54 PM
anubiz84 anubiz84 is offline
Mein Auto: E36 318i
U have mentioned its getting solid after sometime. If its a vacuum leak idle should go high due to the lean mixture.
Check the O2 sensor relay which is powering the heater element.
If you can replace the O2 sensor that would be better. When you are not receiving (Failed sensor) the signal from O2 sensor ur DME orders a fix mixture (Open loop). So in cold condition idle can be rough due to that rich mixture.
And in my car I had a bad idle due to out of tuned (man made) air flow meter. Check it and adjust if it needs an adjustment. But for this u need a exhaust gas analyzer.
fuel, gas, misfire, rough, running rich
