Heater sometimes hot sometimes cold - Bimmerfest - BMW Forums
Old 09-20-2019, 06:22 AM
Raunylima7 Raunylima7 is offline
Mein Auto:
Hi guys! Back again with another one.
It's starting to get cold here, and decided to use the heater. Took forever to warm up, but got warm. 3 minutes later temperature dropped blowed fresh air, 2 minutes later started to get warm again... and so it goes... doesn't stabilize..
It's not on auto, and I adjusted the temperature to the max (91F) to test it out.
Before it gets cold for real I need to fix this, and as usual people overcharge these types of things especially this time of the year where they know you dont have a choice. Has anyone gone through this and could help me out?
Very much appreciated!
Old 09-20-2019, 07:31 AM
dukedkt442 dukedkt442 is online now
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
M54 or N52?
Coolant level check?
Old 09-20-2019, 07:42 AM
Mein Auto:
Originally Posted by dukedkt442 View Post
M54 or N52?
Its a M54, Coolant level is fine...
Old 09-20-2019, 08:51 AM
Sporadic heat often can be traced to air in the system, sticking thermostat or heater valve, or can be a blend door problem in the HVAC control panel.
Old 09-20-2019, 09:46 AM
Mein Auto:
Seems like the answer could te pretty obvious...
I'm just. Concerned about the hot air coming and going every 2-3 minutes. That means I still have some very hot air coming, but it just doesnt last long..
Dont know from where to start to looking..
Old 09-27-2019, 05:57 AM
Mein Auto:
[UPDATE] I noticed the the heater only gets hot when the car is running, when I stop a traffic light the temperature drops... any clue?
Seems like the pressure flow makes it work?
Old 09-27-2019, 06:09 AM
Doug Huffman's Avatar
Nuclear engineer
The Hot-Water Control valve(s) is normally open while de-energized and energized to shut against the flow. It may be throttled shut by a PWM from the IHKA.
Old 09-27-2019, 06:22 AM
Mein Auto:
That sounds interesting, sorry to ask but how will I make sure it's that? Or any suggestions on how to proceed?
Old 09-27-2019, 06:26 AM
Nuclear engineer
www.NewTIS.info
Old 09-28-2019, 03:50 PM
Mein Auto:
www.NewTIS.info
Thank you
Old 10-04-2019, 06:09 AM
Mein Auto:
Update:
Heater started to work regularly with no fix. Don't know if was just lack of use? Certainly not right but let's see how far it goes..
Thanks for the help!
