anyone install M Tech Steering wheel? - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 11-08-2019, 10:34 AM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
Just curious if any of you have installed one of these M Technique Technic BMW Steering Wheel from Poland? Where you able to attached the existing "clock spring" to new wheel? Did everything fit?
https://www.ebay.com/itm/M-Technik-T...0/273208750590
BMW CCA #132981 Tarheel Chapter,
Old 11-10-2019, 07:12 PM
Irwie'C Irwie'C is offline
Mein Auto: an '02
What year is your e34? the wheel in the ad uses a face lift clock spring, instead of an early type sliding carbon contact pin on the slip ring. Also, the splines are different between post and pre '92 e34 columns.
Old 11-10-2019, 07:14 PM
Mine is a '92 535i.
Old 11-10-2019, 07:19 PM
Mein Auto: an '02
Well you'll have to check how your wheel's secured to the column. The changeover happened somewhere in '92 and I can't really remember the exact month.
So, if your wheel is secured with 22 mil nut, means it's an early column. Whereas if it's a 16 milimeter hex bolt is for a facelift column. facelift splines are bigger diameter.
Old 11-11-2019, 06:33 AM
Thanks for info. Here's a pic of my steering wheel. Looks like i have the bolt & from what ur saying, am good for the M Teck wheel.
Sent from my SM-G930R4 using Tapatalk
