F01 Drivetrain malfuction - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 06-02-2020, 08:45 PM
shakmonster shakmonster is offline
Mein Auto: 2008 BMW 335xi
Hello all recently I encountered a check engine light as I was driving with a message that said "drive train malfunction loss of power." When I read the code on my scanner it said cylinder three is misfiring. Prior to this I changed all sparks and both left and right PCV valves car was running smooth until this issued occurred. As of now I took out the cylinder 3 spark and cleaned it and the coil pack put them back in and got the same problem any tips/help would be appreciated.
Old 06-03-2020, 08:22 AM
Poncherello Poncherello is offline
Mein Auto: 2013 750Li
It's a bad coil on #3. I got the same error last summer/fall. Under hard acceleration at first then progressively got worse. Came up drivetrain malfunction error. When I checked the codes I had a misfire of #3 and #7. I was about 10-15K miles over due for spark plugs at that time. I replaced the spark plugs and all the coils myself and no issues again. I would suggest replacing all the coils just because when one goes bad others will as well.
BMW wanted about $1500 for that job. My mechanic wanted almost $1100 for that job. I bought everything on RMEuropean for $265 including overnight shipping. Took me about an hour or hour and a half to do the whole job.
Old 06-03-2020, 08:53 AM
isstatu1's Avatar
isstatu1 isstatu1 is offline
Mein Auto: 2010 750Li
Swap cylinder 3 coil with cylinder 4 or any other and see if the error moves along. Then you'll know it's a bad coil.
Old 06-04-2020, 07:29 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Swap the COP to a different cylinder, & see if the problem follows the COP. Misfires can be caused by a bad spark plug, a bad COP, or a bad fuel injector. If the problems is caused by the fuel injector, there should be a goodwill replacement on it. Call BMWNA & ask them if you injector would be covered at no charge.
