water pump - Bimmerfest - BMW Forums
Old 02-25-2019, 03:45 PM
Z3 freak Z3 freak is offline
Mein Auto: '02 Z3, 05 Jeep Wrangler
water pump
Not needing it yet, but just in case doing research on the best bang for your buck on a water pump for 3.0L engine. Mine does not run hot, but just wondering which brand members have had the best luck with. MEYLE brand on the Pelican website got 5 stars in review with good casting material, but don't know more than that. Just know to stay away from plastic. Will probably change out the thermostat at the same time. Comments on either??
Old 02-25-2019, 04:02 PM
ixmeltxfaces ixmeltxfaces is offline
Send a message via AIM to ixmeltxfaces
Mein Auto: E39 528i
The Stewart water pump will set you back a few bucks but it's the overwhelming favorite from what I've gathered from previous threads. As far as economical options... anything but graf and you'll be alright. The sheet metal construction in theirs tends to be less reliable.
-E39 528i: SOLD
-E85 Z4: SOLD
-E84 X1: SOLD
-R56 Mini: Daily
-E36/7 Z3: Weekends
Old 02-26-2019, 04:38 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by Z3 freak View Post
... Mine does not run hot... Just know to stay away from plastic. Will probably change out the thermostat at the same time...
A water pump will not make the engine run hot unless it comes apart, or the converse, if the engine runs hot, the water pump is not likely the cause.
Plastic sounds terrible, but composite was and still is BMW's OE impeller material. A solid steel impeller will never fail, but the extra weight may shorten the life of bearings and seals. I bought both a Geba steel and a Saleri composite, and decided to use the composite. The sheet metal impeller in Graf pumps can come apart.
https://www.bimmerforums.com/forum/s...4#post29228514
The water pump or thermostat will not cause sudden loss of coolant, but broken plastic parts can. The hose spigot on the radiator, the radiator itself, the expansion tank, and the connector pipe from the engine for the heater. It is convenient and efficient to replace the entire cooling system at one time, including tensioner pulley and belts.
Old 02-26-2019, 04:39 PM
Wow thanks vintage42, and other members for your input. Sorry to hear that members have experience these issues with the cooling system. Seems to be problematic with as few models, but their lost can be our gain with buyers of parts side stepping those products that did not measure up to long mechanical life but have had premature failures...........sad.
Old 02-26-2019, 04:45 PM
Also makes one wonder why such a good product, (BMW), with a good history of reliability would have so many complaints from owners in these same areas experiencing the same problems...........hummm
Old 02-26-2019, 04:48 PM
240Z2Z3 240Z2Z3 is offline
Mein Auto: 2002 Z3 2.5i roadster
I changed all cooling system parts except the radiator at 48K miles. The tech support at Bavarian Auto Sports suggested the radiator was good for 100K. I spent the $$$ for the Stewart pump figuring this would last as long as I own the Z3 which I hope is a long time. I also replaced the thermostat, expansion tank, fan clutch, fan, and every single hose.
Old 02-26-2019, 05:33 PM
vintage42's Avatar
BMW CCA 1405
It is the aging of thin plastic that becomes brittle and weak from age, heat, pressure cycles, and loss of elastomers. After 20+ years and 100K+ miles, I wonder if the plastic cooling system parts in our current cars will hold up any better.
Old 02-26-2019, 05:58 PM
raubritter raubritter is offline
Mein Auto: 2002 Z3 3.0i Roadster 5sp
This was my thinking too (Stewart also flows more coolant at a given RPM than the stock pumps, so in theory should help coolant circulation).
It was also my thinking in getting an aluminum radiator during my cooling system refresh (I got VSL). I don't miss worrying about a plastic radiator breaking...
I also did the fan delete, so I don't worry about the plastic mechanical fan exploding anymore. I added another electric fan (the car already comes with one stock) just in case, but it basically never comes on.
Old 02-27-2019, 10:34 AM
Plastic radiators and plastic fans?? Are either an engineering design approved by corporate for purpose of cutting weight or cutting overhead cost! Also profiting after market vendors knowing that even under normal driving conditions, these parts will sustain premature failure!! Sadly we have to turn to these vendors for a new and hopefully improved product to replace OEM..........
Old 02-27-2019, 11:23 AM
vintage42's Avatar
BMW CCA 1405
Plastic radiators and fans have been the norm on vehicles for decades. They were probably selected for cost and weight, but not for premature failure, whatever that means. The soldered tubes and tanks of the old metal radiators often failed, too.
For the Z3 you can buy all-aluminum radiators, and solid steel water pumps. They cost a lot more.
The plastic pipe connectors from the engine to the heating system would be prohibitively expensive to reproduce in metal. The 4 and the 6 have a long connector pipe that would difficult in metal. And the 4 has a complex Y connector that has doomed many an engine.
Name:	01 Plastic connector.jpg
ID:	841903   Click image for larger version
Name:	09 Plastic connector.jpg
Old 02-27-2019, 11:48 AM
vintage42's Avatar
BMW CCA 1405
I changed all cooling system parts except the radiator at 48K miles. The tech support at Bavarian Auto Sports suggested the radiator was good for 100K....
Forum wisdom suggests the radiator is no better than the rest of the system.
https://www.bimmerforums.com/forum/s...1#post29836901
Did you also replace the plastic pipes?
Old 02-27-2019, 04:13 PM
Occurring or existing before the normal or expected time.
Old 02-27-2019, 08:34 PM
vintage42's Avatar
BMW CCA 1405
What is normal or expected? Is 20 years too short a time?
If/when you replace your radiator, will you buy a 20 year OE plastic Behr, or will you pay for an all-metal Mishimoto?
What modern car are you presently driving, and have you looked at its radiator materials?
Old 02-28-2019, 09:52 AM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
I got a Stewart water pump about 3 years ago and no problems at all.
Mike Swing
Old 02-28-2019, 08:51 PM
vintage42's Avatar
BMW CCA 1405
Is that unexpected?
Old 03-01-2019, 02:14 AM
Mike Swing's Avatar
Mike Swing
Is that unexpected?
Nope. I just wanted to give my +1 for the Stewart water pump.
Mike Swing
Similar Threads
2010 X5 3.0si, water pump went at 93k miles rpoitras X5 E70 (2007 - 2013) 5 11-09-2018 09:36 AM
Water pump version Gac79 X3 F25 (2011 - 2017) 7 05-02-2018 07:20 PM
BMW e90 water pump issue please help Mustafa95 E90/E91/E92/E93 (2006 - 2013) 15 04-10-2018 02:31 PM
Water Pump Thermostat issues 07 550i udawgsw E60 / E61 (2004 - 2010) 1 03-11-2018 11:02 AM
Water Pump recco's for '97 540/6 KenC-VA 5 Series 0 10-23-2003 04:01 PM
