VCG vs Valve Cover Replacement - Bimmerfest - BMW Forums
Old 10-27-2019, 01:27 PM
ZeroDfx's Avatar
ZeroDfx ZeroDfx is offline
Mein Auto: 2008 550i
My 2008 550i w/ 121k miles appears to require valve cover gasket replacements; my oil consumption has increased and I can see oil crud forming between the covers and the engine. I've reviewed a couple videos describing what's entailed to get at the gaskets for DIY, and I'm not inclined to take on the project myself as I did in the past on my E39's.
My local indie gave me an estimate to do the work and it included automatic preventative replacement of the valve covers themselves with OE covers from BMW. Obviously this adds a big chunk of change. I can understand why he might want to approach it this way to ensure there are no further leaks down the road for which he might be held responsible. I have used this mechanic before and I trust him; so I am not concerned about being ripped off.
But how likely is it the existing covers are warped, and couldn't they be checked for warpage before replacing them?
Anyone have any experience with this either way: replacing covers or not? I just want to get a couple more data-points.
Thx
2007 530i sport (Montreal Blue w/ Gray)
2008 550i/6spd (Alpine White /Black)
Old 10-27-2019, 01:33 PM
Toddmori Toddmori is offline
Mein Auto: 2008 550i Sport
I would check the surfaces for flatness before replacing. The gaskets are known to leak, but I haven't heard much about the covers failing without extreme heat involved. Pretty sure they are a glass filled plastic or nylon
Sent from my ONEPLUS A6013 using Tapatalk
Old 10-27-2019, 05:35 PM
tstiglich tstiglich is offline
Mein Auto: 2009 528i xdrive
Keep in mind that the CCV diaphram is integral to the valve cover. I replaced the whole valve cover at 100k for this reason. All gaskets were leaking, and it is a pain in the ass to do. Was worried that the diaphram would go on me before the new gaskets.
Old 10-27-2019, 06:08 PM
Ii was able to replace all 3 diaphragms without removing the valve cover on my 2008. The covers just pop off
Old 10-27-2019, 06:32 PM
May have misspoke then. Not servicable on a 2009 528xi
Old 10-27-2019, 06:37 PM
There is the difference! The N62 has external covers for them. Basically, if they aren't cracked or warped, they should be good to go. There pricing for them is rather obnoxious
Old 10-30-2019, 04:56 PM
OakTone OakTone is offline
Mein Auto: 2006 E60 550i Sport
Originally Posted by Toddmori View Post
Ii was able to replace all 3 diaphragms without removing the valve cover on my 2008. The covers just pop off.
All three? One under a black plastic cover near the front of each valve cover and ó OK, I give up. Where is the third CCV diaphragm? Same engine as yours (N62TU).
ó
OakTone
2006 E60 550i Sport
Sent from my iPad using Tapatalk Pro
Old 10-30-2019, 05:01 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
ó
OakTone
2006 E60 550i Sport
There are only two diaphragms. One on the drivers side valve cover and one by the front of the intake. Both easy to get to and replace. To answer a previous question, most likely the valve covers themselves are not warped on the N62. Only gaskets and o-rings would be needed to reseal it. As preventative maintenance, timing covers should be done at the same time. Might add an extra hour of work but prevents a headache later.
Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 10-30-2019, 05:02 PM
Thx
Your valve covers are probably not warped. Itís not a known issue for the N62. You would need just gaskets and o-rings. Not a hard job. Just have to make room for removal. If you DIY you should do timing covers at the same time. Might add an hour of work but will save work later. I have done this work.
Old 10-30-2019, 05:24 PM
The 3rd is on the hose between the valve covers
Old 10-30-2019, 05:30 PM
Thatís the one I mentioned that was near the intake. There are two diaphragms and a fuel vent valve connecting both banks.
Old 10-31-2019, 09:17 PM
ZeroDfx's Avatar
Are the valve covers plastic or metal (aluminum) ?
Old 11-01-2019, 04:36 AM
Fiber reinforced plastic
Old 11-01-2019, 07:11 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '15 435i '10 535i '08 X5
There is an ebay seller offering replacement CVV diaphragms for N52 engines.
