Climate Controls not powering up - NO A/C - Bimmerfest - BMW Forums
Old 07-23-2006, 05:02 PM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
As I was driving home today, id thought i would turn off the A/C and put the sunroof down. Well, as it started to get hot, I decided that I wanted the A/C again. When I tried to push the A/C on button, nothing happened. I turned the car off and on, and the climate controls will not power up at all!
I JUST got the car back from the dealership to get the thermostat & housing replaced, and the radiator expansion tank. The bleeder valve had to be replaced as well, since it blew off and leaked coolant everywhere. I hope this is not the result of electrical damage and wonder if the 2 could be related. Can anyone help?? Maybe its just a fuse going out, but im not really sure how to go about checking for that.
Edit: On the way home, i heard kind of a screetching sound coming from the engine. I hope this is not the cooling system.. again.
If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them.
-- Henry David Thoreau
Old 07-23-2006, 07:17 PM
Vornado's Avatar
Checked the fuses. I didnt see any bad ones.. Could I just need a new climate control module?
Old 07-24-2006, 06:44 PM
Vornado's Avatar
bump ditty ump
Old 07-24-2006, 07:01 PM
crash8168 crash8168 is offline
Mein Auto:
Try disconnecting the battery to see if it resets.
Old 07-24-2006, 08:19 PM
bitmouse bitmouse is offline
Mein Auto: 2000 323i
Screeching noise? As in a belt squeeling? If it's a belt, then you may see some shredding on its edge.
The environment system does take into account the coolant temp, outside temp, and the car's speed (ref: Bentley manual).
I recommend that you check your A/C belt and coolant level, and see if the system starts up on the following morning when the engine is completely cooled.
Old 07-25-2006, 07:35 AM
Vornado's Avatar
Alright I'll check it out.. thanks for the replies.
Old 07-25-2006, 10:00 AM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
Does your fan come on at all? If not, it might be the Final Stage Resistor... that's what happened in my car... turned on A/C, nada... no air at all...
Old 07-25-2006, 10:10 AM
Vornado's Avatar
Nope, the whole system wont come on. What is a final stage resistor? My A/C doesnt even turn on, the lights on the controls are all dead.
Old 07-25-2006, 10:32 AM
Vornado's Avatar
Reset the battery. That didnt do any good. I just had the whole A/C system replaced, too! My girlfriend thinks my car's more trouble than its worth. Im starting to agree with her.
Old 07-25-2006, 11:40 AM
Salvator's Avatar
Livin' like Larry!
It's a little device under the dash that controls the fans... without it, no flow... fortunately, mine was under CPO warranty, so no muss no fuss... I understand there are DIY instructions floating around if you wish to try to rectify it yourself... Here you go...
https://www.bimmerfest.com/forums/sho...78&postcount=1
Old 07-25-2006, 12:26 PM
Starting to sound like the control unit isn't getting power.
If it has been recently been removed, then it may have not been plugged in all the way.
You can also check fuses 23, 28, 62, & 63.
Old 07-25-2006, 02:15 PM
Vornado's Avatar
I'll take a look. Thanks.
I'm starting to wonder about that. I did just have my evaporator replaced, so they took the dash apart for that. Now that I think about it, it seems to have stopped working after I went over a bump really hard and turned the car off later, it didnt go out right then. I pulled out the console "storage" cube and saw a couple of wires back there. I know one powers the radio.. cause all it seems like is it just basically isnt getting power. The a/c worked great before it just decided to shut off.
Old 07-25-2006, 03:22 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Check out Terry's reply to me:
https://www.bimmerfest.com/forums/sho...hlight=climate
Old 07-26-2006, 09:36 AM
Vornado's Avatar
Got an appt for tomorrow. I'll see what the verdict is. Thanks for all the replies. I'll post again when I discover what the problem was.
If it's the final stage resistor, i'll know why they call it that. After a while, it finally resists working.
Old 07-28-2006, 12:08 PM
Vornado's Avatar
Looks like it was the whole climate control panel (unit). They had to order a new unit, repair cost about $450.. covered under extended warranty.
Old 08-01-2006, 08:34 AM
Vornado's Avatar
UPDATE-- They put the climate control unit in, and the problem is still there!! It blows warm on the right (passenger) side, and semi-cold on the drivers side. warm on the floor vents, and warm on the windshield vents. The compressor works, the evaporater is new, new expansion valve, new hoses, and the charge is fine... no known leaks in the system. Final stage resistor??
Old 08-01-2006, 09:48 AM
Salvator's Avatar
Livin' like Larry!
Final stage resistor, AFAIK, controls the blower fans... when in auto mode, it adjusts the speed of the fan to help cool down or heat up the vehicle quickly... I don't think it would cause one side to be cooler than the other (do you have dual zone heating and cooling?) Seems to me like something is not hooked up right... perhaps they should try another climate control unit?
Old 08-01-2006, 12:38 PM
Vornado's Avatar
No I just have the regular climate controls, no dual zone. Im taking it back today and getting a loaner bmw so they can "further evaluate and diagnose" the problem, taking into consideration they might have screwed up something when they took the entire dash apart for the evaporator service. I cant handle having inadequate cold air flow in this heat & humidity this time of year.
Old 05-18-2009, 12:51 PM
camzdad camzdad is offline
Mein Auto: 2002 330i
Vornado, I have a dead system now like you did. What was your final outcome? Did it take another climate control unit, or was it something further?
Old 05-18-2009, 01:10 PM
jcourcoul jcourcoul is offline
Supporter of Bimmer Lore
Mein Auto: 2006 325Ci
Cold air on the driver's and hot on the passenger's side seems to be a hallmark of low refrigerant in the system. Have them check again and if need be, empty the system, pull a vacuum and reload the appropriate amount of R-134a (2 1/2 lbs, IIRC, check sticker)
2006 325Ci
Old 05-18-2009, 01:40 PM
jcourcoul, any thoughts on the dead control panel? Fuse #28 was blown, I replaced it, and it immediately blew again when the car was started.
Old 05-18-2009, 02:21 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2003 330ci (5 speed)
Did you verify that the amperage fuse you put in it was the correct number? If you put a 5 amp fuse in a 30 amp slot, chances are it is going to blow. Otherwise, you have a short somewhere in the electrical parts. I'd guess you have a bad climate control unit. They run about $90 on ebay.
Old 05-18-2009, 02:35 PM
Thanks smolck. Yeah, according to the insert in the fuse box, #28 is a 5 amp fuse, which was what was in there, and also what I replaced it with. Do you know if there is a way to test the CCU before I buy I new one? And does it need to be programmed? I'm thinking I have a short somewhere as well. After I had replaced the fuse, the panel did light up momentarily before the fuse blew again.
Old 05-18-2009, 02:43 PM
smolck's Avatar
ROLL TIDE!
I am not sure how you would test the CCU. Electrical stuff is not my strong point. But I would say the problem is in the unit itself and replacing it would likely solve the problem.
Old 05-18-2009, 03:05 PM
OK, thanks. I have a Bentley manual on the way, and will probably wait for that to arrive before I attempt the changeout. I haven't seen any DIY's on this and don't want to mess anything else up trying to fix this problem.
Similar Threads
Wood dash trim kit for around climate controls RGHessel E90/E91/E92/E93 (2006 - 2013) 1 02-06-2006 06:11 AM
lights around the a/c controls dont work 94 e36 gokua E36 (1991 - 1999) 3 11-19-2005 05:09 PM
climate controls scott41258 E36 (1991 - 1999) 8 03-04-2005 11:34 AM
climate controls creepyem X5 E53 (1999 - 2006) 3 12-13-2003 12:13 PM
Ne1 want to trade Climate controls? Ausfahrt Do-It-Yourself H.Q. 24 12-27-2002 09:15 PM
