Clear coat is peeling: what to do? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 05-30-2016, 07:23 PM
vlo1788 vlo1788 is offline
Mein Auto: BMW 335xi
The clear coat started peeling after a car wash today, in 2 spots, both about as big as a small tootsie roll. Is there anything I can do to repair it, or will it be crazy expensive to go to someone?
Old 05-31-2016, 01:20 PM
mbanks21 mbanks21 is offline
Mein Auto: 335i
If it is the actual clearcoat there's not much you can do yourself. You sure it's not just oxidization?
Old 06-01-2016, 08:44 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
if the clear coat is peeling them you have paint failure. You can prevent more damage by keeping the area sealed/waxed but the paint will fade and continue to peel as time goes on.
Proper way to fix it is to remove the clearcoat that's failed and reapply, perhaps the base coat of paint too depending on how damaged it is.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 06-16-2016, 01:11 AM
keith8 keith8 is offline
Mein Auto: X5
Not the cheapest but the best and most permanent way to fix it is to repaint and re-clear.
Old 10-10-2019, 06:54 PM
e39s e39s is offline
Mein Auto: 530i
If you have small areas to repair you can try this method of wet sanding, spraying some computer matched base coat, spraying a coat of 2K activated clear, then wet sand again and polish with compound.
