F07 Illuminated Door Sills Problem - Page 2 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F07 Gran Turismo (2010 - 2017)
The 5 Series Gran Turismo - 535i, 550i and 550i xDrive model.
Old 01-16-2019, 02:27 PM
Semi-Retired Semi-Retired is offline
Mein Auto: '14 535iGT xDrive
Originally Posted by tzutzu View Post
Hi...it's plug and play connector with 2 pins...just be gentle not to brake them...it's under the floor mat so you just need long fingers?...it's quite easy to take them out...
I have precisely the same issue with the left rear sill light being out. I have pried the sill off before only to find that there is almost no slack in the wire, as if it's pinched by something. Also, it seems to be routed towards the front of the car as opposed to being routed towards the carpeting. Guess I'll have to pop it apart again for another inspection. I really like that blue led conversion also. If I can figure out where my connector is hiding for the one that's not functioning, I'll start with that one and eventually replace them all.
Old 01-17-2019, 06:30 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Originally Posted by sinless View Post
If you have anymore questions, please ask !!!
Do you have the value of the resistors please - its hard to tell the colours from the image. Also what voltage are the LEDs - 12v?
Old 01-17-2019, 08:36 AM
Silver Shadow Silver Shadow is offline
Mein Auto: 2011 BMW 535i GT xDrive
From an earlier post by milnei: 390 ohm, 12 V, 3 mm LED.
Old 01-18-2019, 07:02 AM
Mein Auto: 750iL
Cheers thanks for that - into my library of info for when they fail!
Old 01-18-2019, 01:18 PM
You can purchase ready made leds with the resistors already built in on ebay very inexpensively. That's what I'm going to do. I've see bundles of 20 on there for $5 t0 $6 (US).
Old 01-18-2019, 01:31 PM
Incidentally, are those 3mm led's that you used for replacement?
Old 02-25-2019, 03:00 PM
Never mind. I'm an idiot. You already answered that question.
Old 03-24-2019, 02:09 PM
Ovidiu.Alex90 Ovidiu.Alex90 is offline
Mein Auto:
Today after my last door sill (driver side) has give up. I've decided to start and fix all of them, is quite fiddly but it can be done, and the result, are awesome! I have use 3mm white led with a resitor already soldered, brought from ebay, the cheapest one, as i use them in the past for various projects and they last for ever.
I scrap that ribbon cable as is not nedded it it may potentially cause other issues.
Tools used were: knife, solder iron, Glue gun, a solid kater. It took me 4 hours to get it done, and half an hour to find the right toola to get the job done.
ID:	845163   Click image for larger version
ID:	845165   Click image for larger version
ID:	845167   Click image for larger version
ID:	845169   Click image for larger version
ID:	845173   Click image for larger version
ID:	845175   Click image for larger version
ID:	845177   Click image for larger version
ID:	845181   Click image for larger version
ID:	845185   Click image for larger version
ID:	845187   Click image for larger version
Old 04-11-2019, 08:44 AM
templeugrad templeugrad is offline
Mein Auto: 2010 550i GT
That looks great. I thought about buying the LED door sills from eBay. They look pretty good. I watched a couple of video of guys that have them on BM’s as well. What’s your thought on them??
Old 08-26-2019, 12:29 PM
ccramerusc ccramerusc is offline
Mein Auto:
My 2016 had the divers side go out, so I bought one from eBay to replace it. Now all 4 don't work. Does anyone know if there is a fuse somewhere? There's so many of them split between two locations, and I can't find a list of which one does what.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Old 08-26-2019, 12:53 PM
Mein Auto:
Well I found the fuse. It's #5 in the glove box (10 amp).
Unfortunately for me, the fuse only got the two on the passenger side working.
Old 09-09-2019, 07:00 PM
Mein Auto:
I finally got around to taking it apart and replacing the led with an orange one from eBay as described above. Worked perfectly. Cost me $1.69 for 8 lights. I replaced the two on the driver's side and they look good as new. Thanks for the info above!
