2014 650 vibration - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - 2018)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 04-05-2019, 07:58 AM
6series 6series is offline
Mein Auto:
2014 650 vibration
Bought last summer with 26k miles, beautiful car. Been to dealer 5x, they acknowledge the issue but after replacing drive shaft, cat, force balance tire, replaced tires, o2 sensors. The vibration starts between 35-40, 50 and 70, it's not drastic but everyone in the car feels it. It's particularly prevalent when the car is in cruise control going up a hill putting a load on the engine. Have have about six months of warranty left on a car and hopefully someone out there has an answer. Thanks
Old 04-12-2019, 12:03 PM
Mein Auto:
Anybody else out there?
Old 04-12-2019, 03:26 PM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
[QUOTE=6series;12962765]Bought last summer with 26k miles, beautiful car. Been to dealer 5x, they acknowledge the issue but after replacing drive shaft, cat, force balance tire, replaced tires, o2 sensors. The vibration starts between 35-40, 50 and 70, it's not drastic but everyone in the car feels it. It's particularly prevalent when the car is in cruise control going up a hill putting a load on the engine. Have have about six months of warranty left on a car and hopefully someone out there has an answer. Thanks[/QUOT
Is this vehicle X-drive?
Old 04-12-2019, 03:32 PM
Mein Auto:
No X drive
Old 04-14-2019, 04:55 AM
madminion madminion is offline
Mein Auto: 335d
Hi same here with 530d F07. You can provoke it by going around 60 and manually putting it in the highest gear that transmission allows and accelerating using more torque than normal. You will be hearing clear rumbling sound and slight vibration. I am going to check mine on Tuesday. My mechanic suspects one of the guibos- balancing/damper bearing or differential. One of the members in different thread (7 series) had loose screw on the diff, others still didn't solve the problem.
Old 04-15-2019, 07:24 AM
dagoo98's Avatar
No X drive
Have figured if it's throttle related (must be accelerating) or speed related (still get the vibration cruising at the speeds you mentioned)?
Old 04-15-2019, 06:00 PM
Mein Auto:
Responding to the last 2 posts. Vibration is caused when accelerating and load, like a hill. I'll see about checking a differential that seems to make some sense. BMW spent $10,000 in parts on this car why would they check the differential?
Old 07-21-2019, 07:10 AM
Thecastle Thecastle is offline
Mein Auto: Bianca the 335d
I have the same issue with my f10 550i. I get vibration that can be felt in the seat and body when accelerating somewhat hard in the 55-75mph range in top gear. Don't feel it at full throttle and don't feel it at higher or lower speeds. Also lower gears seem to reduce the issue.
Just as a data point I had a similar issue that wasn't resolved on my 335d. I suspect the issue was a bad rear diff. We eliminated wheels, tires, brakes, etc. the reason I suspect it was a bad diff is tHe issue became more noticeable when using poly subframe mounts. It also only had the vibration issue under hard acceleration in high gear.
Old 07-21-2019, 07:36 AM
Mein Auto: 335d
Just another suggestion to solving the problem. My problem was in the end a remap where suddenly after 4 months gerbox started to make those vibrations because torque was to high. This is a feature in gearbox to do this so check remap first.
Similar Threads
2014 528i Bad Engine Vibration when Cold - Engine Mounts? Ride Everything F10 / F11 (2011 - 2016) 21 05-25-2019 07:04 AM
Vibration from rear at 37 mph (59 km/h) e93to E90/E91/E92/E93 (2006 - 2013) 7 08-21-2018 01:01 AM
2014 750ix Tire / Vibration luv4greenleaves 7 Series - F01 / F02 (2009 - 2015) 4 08-14-2018 08:06 AM
FS:Xenon Light Control Unit BMParts954 Mobile Electronics and Lighting 0 04-30-2018 12:14 PM
2014 F30 Vibration while in D/R and stopped at light ctravis0928 F30 / F31 / F32 / F33 / F34 / F36 (2012 - current) 2 03-01-2018 08:12 PM
