What's the best way of fitting wheel hub bore size 72.56 wheels onto our hub bore siz - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 F15 (2014 - 2017)
The all new F15 BMW X5 started production August 2013 as a 2014 model year. The new X5 arrives in sDrive35i (RWD), xDrive35i, xDrive50i and a diesel xDrive 35d.
Old 05-11-2019, 08:16 AM
irwinoe64 irwinoe64 is offline
Mein Auto: 2007 BMW M6
I bought wheels from a private seller thinking they'd fit perfectly. Unfortunately, the wheels are 72.56 and our hub size is 74.10. If possible, what's the best way of getting this to work??
Old 05-11-2019, 09:10 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Find a local place that can precision bore out your wheel hubs (if you don't have the machinery/tools)...or invest in wheel spacers that can bridge the 72.56mm hubbed wheels to your 74.1mm wheel hubs.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 05-11-2019, 09:28 AM
Thank you. I was just reading that I can get the wheels drilled. Just gotta do some research. I didn't want to do spacers but I see that ECS sells adapters. They're pretty drastic with the 20mm and up sizes. I really don't want to go any higher than 20mm if that's my only option. I'm going to look into getting the wheels machined first and if that's not possible then I'll look into spacers.
Old 05-12-2019, 06:45 AM
RW RW is offline
Mein Auto: 14 535D x-Drive 16 X5D
Hub Rings
Spacers and hub rings are two different things.
You want hub rings.
Old 05-12-2019, 07:06 AM
You want hub rings.
Correct me if I'm wrong but aren't hub rings used to fill the gap when the vehicles hub bore is too small for the bigger wheel bore? Bc that's not my situation. I'm opposite, my cars hub bore is 74.10 and the wheels are 72.56. In short, the wheels are too small for my hub bore.
Got 15mm spacers from ECS that do the conversion and called it a day.
Old 05-12-2019, 07:08 AM
Spacers were only $260. Got quoted to have the wheel bore machined out for $400. I'm going to call a couple of other spots that can drill while I wait for the spacers. If I get lucky and find someone who can drill on the cheap I can just return the spacers.
Old 05-12-2019, 10:55 AM
RW RW is offline
I stand corrected.
Old 05-13-2019, 06:52 AM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
@irwinoe........saw some interesting hub dia info here. https://www.bimmerworld.com/About-Us...6-Wheel-Specs/
BMW CCA #132981 Tarheel Chapter,
Old 05-13-2019, 07:34 AM
Thanks. Good read. I find it crazy that they felt compelled in changing the bore size. That's why when I bought these wheels privately, from another BMW owner, I never thought the bore size would be an issue. Lesson learned.
Old 05-14-2019, 02:08 PM
PAX5 PAX5 is offline
Freude am Fahren
Mein Auto: X5 50i
If theses are BMW X5 wheels, they must be from a BMW E53 series.
What is the BMW style number - see http://www.bmwstylewheels.com/X
PAX5
BMWCCA #20645
Old 05-14-2019, 02:40 PM
They are not bmw wheels. Off brand.
Old 05-18-2019, 02:37 PM
QSilver7's Avatar
If you're going to go with using spacers...don't forget to check if you'll need to add new wheel lug bolts to the cost equation in case your original ones will be too short to secure the wheel AND the spacer to the vehicle's hub.
(SOLD)
Old 05-24-2019, 10:35 PM
Boy do I need wheel arches
Old 05-25-2019, 04:43 PM
Attachment 853027
How much spacer offset did you end up with?
Old 05-30-2019, 04:16 AM
So I currently have 15mm spacers on. I was told by several mechanics that I can't go any lower bc the hub on the car is already 15mm and I would need to at least clear that to properly fit the conversion spacers. With the wheels going out so far, I shouldn't have any problems right?
Old 05-30-2019, 08:30 AM
@irwinoe.......OK, that why the stick out so far. I have a set of 11" wide on our '15 X5 without the wheel well extenders & they are OK IMO. But with another 15mm (.600") for the spacers will make a lot of visual difference, as well as road trash on car thrown up my the tires. I added splash/mud guards to ours & it helps a lot.
Old 08-06-2019, 06:36 PM
Finally got my flares on
Similar Threads
Tires Help, If You Please?? KaptainKaos54 E39 (1997 - 2003) 12 07-10-2017 08:43 PM
BMW Inventory Blow Out | HRE and ADV.1 In Stock, No Waiting! | F10 M5, M3, 335i, etc. [email protected] E90/E91/E92/E93 (2006 - 2013) 4 05-16-2013 09:47 AM
2000 540i BRAKE, ABS, and DSC lights on, HELP!!! LoganWolf E39 (1997 - 2003) 29 05-16-2012 07:48 PM
HI | Forgestar Wheels In-Stock and Ready to Ship! Great Prices! [email protected] Site Sponsors & Bimmerfest Group Buys 0 10-20-2011 10:35 AM
