Correct wheel offset - Bimmerfest - BMW Forums
Old 09-16-2002, 02:16 PM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
I am looking to replace the stock M Coupe (2000) wheels and want to get the offset correct. What is stock offset? and should I change it when replacing the wheels?
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit, 1-touch lane change,
UUC Stage 2 flywheel/M5 clutch,
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler,
Trafficpro, A-pillar gauge kit,
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 09-17-2002, 09:30 AM
Ron Stygar's Avatar
19,585 Miles
Stock offset is:
Front 7 1/2Jx17 ET: 41 mm
Rear 9Jx17 ET: 8 mm
Old 08-16-2004, 12:06 PM
samer555 samer555 is offline
Mein Auto:
Smile
Given the few wheels that fit the MZ3's because of the unusual offset, is there a formula to figure out if a certain wheel will fit an M Coupe/Roadster. For example, if we take Ron's info about the front wheel being 7.5 inches wide with a 41mm offset, do the mathematics look anything like this:
7.5" x 25.3mm = 190mm in terms of width. Then you divide that number by 2 to get to the center of the wheel width, which is 95mm, and then add (or is it subtract?) the offset number of 41mm, which will be 136mm or 54mm (depending on how messed up my calculations are ). Can this final number be used as a comparison of width/offset ratio on all wheels to figure out if it would fit an MZ3. Appologies in advance if I'm way off.
Old 08-16-2004, 01:08 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
What I always do is to make 2 sketches side-by-side with all that info, one for the stock and one for the potential wheel. Then determine the proper tire size for each (if different), then look at the differences between the two and see if the additional clearance required on the inside and/or outside is available on the car.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 08-17-2004, 07:52 AM
GV from Belgium GV from Belgium is offline
Mein Auto: Z4 2.5
OR.... you can use this offset calculator...
http://toy4two.home.mindspring.com/offset.html
greeeetz from Belgium
Old 08-17-2004, 10:46 AM
Mein Auto:
Thanks, that is exactly what I was looking for. Anyone know the tolrances for reduced wheel well clearance and increased offset for clearance of the wheel arch for the M Coupe/Roadster?
