E83 p0201 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 09-27-2019, 06:00 PM
gsteere gsteere is offline
Mein Auto:
E83 p0201
My 2008 E83 X3 has an intermittent issue where it runs rough and turns the engine light on.
Error code is P0201.
I've swapped spark plug, ignition coil, and fuel injector position with from cylinder one to another cylinder, but I keep getting the P0201 error.
(Cylinder one is closest to the radiator, right?)
Any suggestions? It's driving me a bit nuts.
Would a better code reader give more detailed info in this area?
e83 engine running rough, p0201, x3
