Fixing Blind Spot Problems - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 F15 (2014 - 2017)
The all new F15 BMW X5 started production August 2013 as a 2014 model year. The new X5 arrives in sDrive35i (RWD), xDrive35i, xDrive50i and a diesel xDrive 35d.
Old 01-19-2020, 08:29 AM
Milam Milam is offline
Mein Auto: 2017 BMW i3
I have a 2018 X5 with Blind Spot.
The indicator is hard to see at times.
Question?
Help Appreciated: I am thinking of ordering the 2019 mirrors for the X5. These are much brighter Blind Spot, plus much easier to see.
The 2019 works much better than 2018.
Any suggestions?
My 2nd Generation Nissan Leaf has a better Blind Spot than the 2018 X5.
The 2019 is much easier to see and interpret.
Am I an idiot?
Trying too hard.
Do they evern fit?
Old 01-19-2020, 12:47 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
If you were to look up the part number for the newer mirror glass used on the G chassis X series...then use the part number search on those part database sites...you'd see that only the G models are listed. This means that there is something different going on and will not be a plug-n-play swap.
First, the location of the blind spot indicator on the F15 is closer to the driver and they're peripheral vision...as well as being located on the base of the mirror. That means that's were the wiring goes. On the G chassis BMWs that have the blind spot indicator moved further away from the driver and is embedded in the mirror glass...means that the wiring will need to go to the mirror glass.
If you flip the mirror glass over to look at its electrical connections...you'll need to determine how to get the wiring from the F15's location to the location to power the indicator in the G05's mirror glass. It's not that its impossible since the mirror glass is the same shape...and if you don't have the blind spot feature...the mirror glass is the same part number (#1 & #5 in the diagram). But if you want to install the #2 & #6 mirror glass...you'll need to work out the electrical wiring:
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 01-19-2020, 06:36 PM
QSilver7
Thank you very much.
I have a friend who is a pretty decent mechanic.
I will send this to him.
I will let you know how it went.
The 2019 was brighter and much easier to see than my 2018.
This BMW is not leased.
/s/ Tom MIlam, Jr.
[email protected]
