H&R Race Springs, Will They Rub... - Bimmerfest - BMW Forums
Old 12-14-2017, 02:15 PM
KingOne KingOne is offline
Mein Auto: 08 BMW e60 528i
So Im Buying Lowering Springs This Weekend, And I Have Done Hella Research On The Matter And Finally Decided To Go With H&R, But I Can Not Make Up My Mind Between The Race Or Sport Springs... I Really Want The More Slammed Look So I'm Most Likely Going To Go With The Race Springs That Will Drop My Car The Full 2 Inchs Instead Of The 1.4-1.6 With The Sport Springs...
Right Now My Car Is Sitting On 225-50-17 Stock Rims And I Want To Know If Anyone Has Put Race Springs On A 528i And Have They Had Any Issues With Rubbing Or Did They Have To Do A Fender Roll, What Spacers They Got Away With Without Issues, Etc... Etc...
I Have Style 5 BBS Rims From The Old 5er Im Restoring Currently That Are The Same Size As My Current Stock So I Plan To FlipFlop Rims When I Drop So Tire Size Wont Change...
I Have Read From Many That The Sport Springs Don't Even Need A Fender Roll And People Run 15mm Spacers Front & Back No Issues, But When I Look For Info On The Race Springs, I Cant Find Much About People Running Them Or Any Issues They Had...
Old 12-14-2017, 03:48 PM
Etherghost Etherghost is offline
Mein Auto: yanks mad!
I assume you have 8j rim width which will not be an issue with rubbing. Also, what's the offset on the rims you are restoring. This info is crucial to making a decision on spacer size.
Sent from my SAMSUNG-SM-J120A using Bimmerfest mobile app
Old 12-14-2017, 04:27 PM
STR8-6IX STR8-6IX is offline
Banned
Mein Auto: 2011 535i, 2009 328i
lowering springs ride like ****, you clearly havent done enough research if you have decided to buy lowering springs. unless your car has the lowered sport suspension from the factory i do not recommend it. look into the bilstein b12 kit, fortune auto coilovers, ohlins, BC racing, KW, etc.
Old 12-14-2017, 10:20 PM
Thank You EtherGhost Thats Exactly What I Wanted To Hear... I Do Currently Have 8J but I will Be Installing E39 BBS RC090 17x8 +20mm
& Str8 Six I Wish I Could Afford Coils Right Now But My Pockets Are Tight, I Just Got My Car Back From The Shop, Replaced The Tranny For $4700 at 101k & I Don't Have Sport Suspension But Have Konis Installed At 90k
Old 12-14-2017, 11:02 PM
Banned
Thank You EtherGhost Thats Exactly What I Wanted To Hear... I Do Currently Have 8Js but I will Be Installing E36 BBS RC090 17x8 +20mm
Oh so then youre good, you dont need coilovers. I recommend eibach springs over H&R though. The drop is not as aggressive but the car will ride better.
Old 12-14-2017, 11:05 PM
Sorry to hear about the tranny... About the look of the car... Are you aiming for flush look?
Old 12-14-2017, 11:06 PM
Any Reasons Why In Particular, I Read The Eibachs Give The Car A More Raked Look, The H&R Race Springs Looked Like The Biggest Drop I Could Find From Springs Without Going To Coils...
Old 12-14-2017, 11:08 PM
Yah I Wanna Go As Flush As I Can Without Rolling, Maybe Roll Down The Line, But Just Gonna Drop And Add Spacers To Start
Old 12-17-2017, 12:08 AM
So I Just Pulled The Trigger On The H&R Race Springs, Should Be Here By Next Wednesday...
Any Opinions On What Spacer Size I Should Run With Those BBS Rims They Are +20
528i, 5er, 5series, e60, fitment, h&r, lowering, lowering springs, slammed, spacers, springs, stance
