Having trouble removing the alternator, ASAP... - Page 2 - Bimmerfest - BMW Forums
Old 05-27-2018, 02:58 PM
deroy deroy is online now
Mein Auto: X5 e70 4.8
I see. Never had to do this job myself.
Verzonden vanaf mijn iPhone met Bimmerfest
Old 05-27-2018, 03:25 PM
Semerka Semerka is offline
Mein Auto: 2014 435, 2007 X5
Never have I. But we are living through economy crisis with aging vehicles. I just replaced vacuum pump gaskets for $26, whereas the BMW mechanics would charge me $900
Old 05-28-2018, 03:31 PM
Originally Posted by Doug Huffman View Post
newTIS.infobeta
Home / BMW E70 X5 4.8i SAV / Repair Manuals and Technical Data / 12 Engine electrical system / 12 31 Alternator with Drive and Mounting Parts / 12 31 020
Removing and installing or replacing alternator (N62)
https://www.newtis.info/tisv2/a/en/e...-parts/GUMKp5R
Doug,
Thank you and others for helping me out with alternator the other day. I removed it, now the thermostat gasket thing... I am too new to the 'fest, so I can't figure out how to find here one probably simple answer to my very simple question: were is the camshaft position sensor is (are) for N62 BMW x5 4.8i E70 engine? One thing if you can advise how to search the database, and the other - if you have an answer to my technical question.
Old 05-28-2018, 04:57 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
Originally Posted by Semerka View Post
Doug,
Camshaft sensors (2 each bank, exhaust and intake) are under the valve cover towards the end near cylinder 4 and 8. Their connectors go through the valve cover.
Doug may extend my answer here for the search, but here is my method:
Start from here: https://www.newtis.info/tisv2/a/en/e70-x5-4.8i-sav/
I either walk though the categories or I use the search function on the right. Get's better once you gain experience there.
My other source is http://www.realoem.com where I search for the part number. Then I put this part number in google and search for images.
Example for the cps sensors:
search on NewTis https://www.newtis.info/tisv2/a/en/e...amshaft+sensor
here I click on "Wiring Diagram (SSP) Intake camshaft" Wiring Diagram (SSP) Intake camshaft
On the wiring diagram I click on the blue label of the part: B62241 NewTis link for B62241 and this brings me to related links. First one is "Installation location" Installation location B62241
As for how the part looks like (realoem became very slow recently): Realoem
search for camshaft: Camshaft
then put it in google and search for images: Google search for cps
2010 BMW 550i MT
2003 BMW 325i @216k and counting
1998 BMW 528i MT @ 231k //sold
1997 Saab 9000 //sold
Old 05-29-2018, 05:57 PM
Redlined0002 Redlined0002 is offline
Mein Auto: 2013 BMW X3
Most alternators have a split bushing inside the lower rear hole that moves inwards towards the bracket when you tighten the bolt. Sometimes they are difficult. You have to get a screwdriver or pry bar between the alternator and the bracket and pry upwards.
Old 05-29-2018, 07:23 PM
Thank you, I had noticed that on both a drawing and then somewhere where they talk about pushing that bushing back into the back hole of the fork (bracket) before re-installing the alternator. I was able to create a better gap using a 10 inch pry bar. A gap of 1 mm or so lets it sled out quite nicely.
Bottom line is: thank to you all, the alternator has been removed, washed and prepared for re-installation. Problem's solved!
4.8i, alternator, e70, gasket, leak, n62 oil leak, oil thermostat, x5
