Coolant from block. Is my E39 dead? - Bimmerfest - BMW Forums
Old 08-27-2018, 02:21 PM
DaveToon DaveToon is offline
Mein Auto:
So this is not a shot from my car, but it is the closest photo I have found so I can show where the coolant is coming out. I searched but haven't found this issue online... it is hard to see but it looks as though a spot where a pipe was attached to the block just behind where the Thermostat mounts. (The pipe appears to be separated) The car runs like a top but I guess doesn't matter if the coolant pours out! (
Just want to know if it is fixable or time to move on. (2000 528i, 180,000 miles)
Thanks!
Name:	BMW issue.jpg
Old 08-27-2018, 04:10 PM
Columbo Columbo is offline
Mein Auto: BMW E39 520i
Definitely fixable. Take more photos please. Zoom in. Clean everything around that and lets see where exactly it is coming from. Maybe consider talcum powder around there to detect more clearly where it is coming from.
Old 08-27-2018, 07:14 PM
Mein Auto:
Hey Columbo thanks for your reply! the issue is it's really hard to see it's underneath the manifold and behind the oil filter and it definitely seems like a pipe or something broke away from the Block and it's pumping out a bunch of fluid when I look back there it definitely looks like a hole in the aluminum but I'm trying to determine if I should spend the time taking the manifold off. definitely no way with the manifold off to get a good view of it but I will see if I can get a video camera to get some kind of angle to get a better View I'm just wondering if there is a connection there with the pipe or just simply blew out
Old 08-27-2018, 08:20 PM
effduration effduration is offline
Mein Auto: '99 528i, '03 530i '06 X5
Yeah those are the two hard plastic heater pipes that are under the intake manifold. They basically deteriorate with age and heat cycles and eventually crumble where they enter the head.
No reason to junk the car if it hasn't overheated. Find a good Indy mechanic to remove intake and replace the pipes or do it yourself.
Old 08-27-2018, 08:28 PM
Mein Auto:
hey thanks for the reply! it did overheat so that is concerning though it still fires up just fine but I'm not sure if it warped or not I might just make a project of it and remove the manifold myself otherwise it'll just sit here anyway!
Old 08-27-2018, 08:54 PM
Yeah these cars don't take an overeat very well. Any more than 60 seconds in the red and you likely have a warped head. You might do a compression test before proceeding any further.
On the flip side the '99 and '00 528i's are as durable as they come. if the rest of the car is in decent shape it would be worth getting it back on the road.
Old 08-27-2018, 08:59 PM
Mein Auto:
Thank you! Yea been in the family since new and no accidents and very straight rust free california car. Ive done a ton of work on it including recently changing the driveshaft cv joint so i would hate for all that work go to waste but i also dread doing another huge repair job... ***x1f642;
Old 09-24-2018, 10:11 AM
Mein Auto:
Coolant pipes
Thanks all!
It was a monster job but got it apart and replaced the lines and put it back together and so far it seems to work. (Fingers crossed!)
ID:	820191   Click image for larger version
Old 09-24-2018, 06:41 PM
cn90 cn90 is offline
I think 1997-1998 is metal.
1999-2003 is plastic, too much plastic in the car these days. This plastic issue only comes up after 100K.
Just curious how many miles in your car when this happens?
Old 09-24-2018, 08:05 PM
Mein Auto:
The car has 185,000 so the plastic lasted quite a while! Whats crazy is the starter is under there as well...
QUOTE=cn90;12744501]I think 1997-1998 is metal.
Just curious how many miles in your car when this happens?[/QUOTE]
528i, block cracked, coolant
