Airbag lamp e39 528i 1999 - Bimmerfest - BMW Forums
Old 02-16-2019, 08:40 AM
sxisoxs sxisoxs is offline
Mein Auto:
Hi
I have an issue with the airbag lamp on my car.
I had some trouble with the heating mat in the front driver's seat and took the whole seat out of the car to get it fixed. Long story short, I had to unplug the wires from the seat while the battery was connected. I knew it would trigger the airbag lamp, but I had no other choice.
Took it to two different shops that tried to reset the airbag lamp, but they couldn't even enter the airbag category. They confirmed that the tools usually was able to do it on BMW.
So I have tried different stuff like, disconnecting the battery and letting it stay overnight before plugging it in. Also unplugging the seat connectors and fuses. all with no luck. The lamp still returns when fuses are back in and the seat is connected.
I am confident that this has nothing to do with the occupancy sensors as it was triggered by the fact that I removed the seat as I explained.
So I noticed that fuse nr 40 is both listed under airbag and instrument cluster. Tried to remove it and the lamp finally stopped. nothing happened when I removed fuse 42 which is only listed under airbag.
So the question is, does anyone know how to fix this? And can I just remove fuse 40 to avoid the annoying lamp? or will this cause the airbag to not deploy if Icrash?
Thank you in advance!
Old 02-16-2019, 10:03 AM
cn90 cn90 is online now
Search forum for "E39 airbag emulator".
Ebay sells it for $15.
QSilver7's Avatar
QSilver7 QSilver7 is online now
Mein Auto: 2006 X5 4.4/2013 650ix GC
If you use the newtis.info website...you can look up fuse 40 (F40) and see exactly what it powers.
I entered generically for an e39 528i...then typed "F40" into the search box...and it pulls up this wiring schematic: https://www.newtis.info/tisv2/a/en/e39-528i-lim/pe27Fh8
When you look at the wiring schematic...you'll see that it controls the electronic seat control (A113)...and instrument cluster (A2)....and the mat sensor (I01009) The things in the schematic that are in blue text are clickable links that will take you to additional information. If you click on those links you'll see that there is information for PIB (pin out information)...and if you go to those....you can see what is powered by fuse 40 in the instrument cluster and electronic seat control...and those things may be what is causing rejection of SRS reset.
If you pull fuse 40...then those things will no longer be powered.
In regards to the air bag light...if you are trying to reset the light and the SRS (supplemental restraint) warning light won't reset...then that is an indication that something in the system has not been repaired...thus the light won't reset. You may need to check and recheck the seat connections and the control module to see why after reconnecting the electrical connections are not resetting when you connect to SRS to do a reset.
Good luck.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 02-16-2019, 04:02 PM
Mein Auto:
Thank you @Qsilver7.
I'll try to clean the connectors with some electrical cleaner spray.
It's just so strange that something suddenly is "broken" when all I have done is remove the seat and reinstalling it again.
I am not really that familiar with electronics and wiring diagrams. But I now see that fuse 40 also powers the electronic seat control.
Hopefully the cleaner will help, or else I am lost.
Old 02-17-2019, 04:23 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3, 528i, M5, X5, Jetta
Where are you located? If you are near NJ Id read the code for you.
Sent from my iPhone using Tapatalk
2000 Z3 2.3
2003 M5
2004 X5 4.8iS
2016 428xi coupe
2018 M2
Old 02-17-2019, 02:02 PM
Mein Auto:
Thanks for the offer! I live in Europe though
Old 02-17-2019, 02:37 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
Originally Posted by sxisoxs View Post
Hi
btw, you do have another choice, when working with any of the airbags, the rest of the SRS system, and other electrical repairs. disconnect the - battery cable. no airbag/srs lite will be set.
99 528i 5sp sport
be alert...the world needs more lerts
Old 02-18-2019, 08:08 AM
Mein Auto:
Yes, I am aware of that. But as I said, I had no other choice to do it that way.
Old 02-18-2019, 08:11 AM
Mein Auto:
Thanks again..
I decided to go to the official BMW shop where I live and they hooked it up to INPA and got the SRS lamp deleted.
No faults with the system. So thankfully its gone now.
The other shops I went to first didn't have the correct obviously!
Old 02-19-2019, 09:48 AM
amancuso's Avatar
Ok. Best of luck sorting it out!
2000 Z3 2.3
2003 M5
2004 X5 4.8iS
2016 428xi coupe
2018 M2
528i, airbag, e39
Similar Threads
Is a 1999 528I A good track car? Aiden Fox E39 (1997 - 2003) 14 10-31-2018 10:08 AM
Will a 2002 325i GM 5L40-E transmission work in a 1999 528i 4-speed automatic car ? nj7783 E39 (1997 - 2003) 4 06-08-2018 06:27 AM
Airbags and full face helmets clyde Motorsports, Racing & Track 43 11-20-2004 11:44 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 04:45 AM
