2014 528i False Coolant Level Low Message - Bimmerfest - BMW Forums
Old 07-02-2019, 09:52 PM
7611wpd 7611wpd is offline
Mein Auto: 2002 BMW X5
I have a 2014 528i that just made 100K miles and after a trip to the dealer for the last CPO check and an oil change, I received a Coolant Level Low Message after a 250-mile trip. It did not need hardly any coolant, but I topped it off anyway. Well, although it is full of coolant, the message keeps coming back. I have bleed it a couple of times with the 10-12 minute electronic bleeding procedure, but the message continues to return. We have driven it over 500 miles since the first message and it never runs hot and although full of coolant, the Coolant Level Low Message continues. Am I missing something? Any thoughts?
Old 07-02-2019, 10:16 PM
v8power v8power is offline
Mein Auto: 2011 X5//M
Coolant reservoir tank has a float switch(magnetic) that signals the sensor (under the reservoir). I've had the float switch go bad, stuck or the foam that float it had broke off. A new tank should comes with a new sensor also. A liter of concentrate coolant too that will make 2 liter when mixed. Btw do not buy aftermarket reservoir. I usually go aftermarket with parts but with bmw on this particular part, go oem.
2013 550i
2011 X5 35i Sport (totaled)
2007 E92 335i
2008 550i
Old 07-02-2019, 10:17 PM
Coolant reservoir tank has a float switch(magnetic) that signals the sensor (under the reservoir). Iíve had the float switch go bad, stuck or the foam that float it had broke off. A new tank should comes with a new sensor also. A liter of concentrate coolant too that will make 2 liter when mixed. Btw do not buy aftermarket reservoir. I usually go aftermarket with parts but with bmw on this particular part, go oem.
2013 550i
2007 E92 335i
2008 550i
Old 07-03-2019, 12:11 AM
This sounds great, so I will check out the reservoir itself and pursue replacement if necessary, then let you know how it turns out. Thanks!
Old 07-03-2019, 08:11 AM
Raymond Lee Raymond Lee is offline
Send a message via AIM to Raymond Lee
Mein Auto: BMW and MBZ
Current reservoir is probably cheapest design made in China. BMW does use cheap parts in the name of cost saving!
Old 07-03-2019, 08:24 AM
bmrboy2008's Avatar
bmrboy2008 bmrboy2008 is online now
Mein Auto: 2014 535i M Sport
At 59K miles my reservoir has developed a very small leak and will have to be replaced soon.
2014 535i M-Sport, Jet Black, Black Dakota Leather, Premium Package, Lighting Package, Multi-Contour Seats, M-Sport Suspension, Navigation, Harmon Kardon Stereo, 3M Tint
2008 528i Sport - Retired
2008 535i Sport - BMW Buy Back
2004 525i Sport - RIP
2014 5 series, 528i, coolant bleed, coolant level low message
