Suspension response after installing 20" Rims - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 07-11-2019, 05:46 AM
sherif10 sherif10 is offline
Mein Auto:
Hi Guys ... I have a 2019 BMW 5 Series G30 , I have installed 20" Rims and installed 245/35/20 in the front and 275/20/30 in the rear . I have kept the factory shock absorbers and springs and have not made any amendments to the suspension . Now , the rear tires have a slightly bigger gap with the fender that I would like to reduce , and the front tires I feel some vibration ( oscillations ) in the suspension on slightly uneven roads ( as if there is a problem in the shock absorber ) ... what should I do ? should I change the Springs or the Shock Absorbers ? Which types should I get ?
Thanks every one for your help .
Old 07-11-2019, 06:23 AM
jjsC6 jjsC6 is offline
Mein Auto: See Sig
What was on it before, and which suspension do you have? It would also help to know what the tires and wheels are. Are they BMW wheels, standard offset etc?
2017 BMW 540 M-Sport Carbon Black/Ivory
2016 Lexus GX 460---Wife's car
Bikes...2017 Yamaha FJR1300---2020 Kawasaki 1000SX---2012 Ducati Panigale
Previous BMW: 2012 550 M-Sport
Old 07-11-2019, 09:30 AM
silberma1 silberma1 is offline
silberma1
Mein Auto: 2018 540i
You need to understand that the car is designed as a system. Changing a few parameters will affect the system and require a computer dynamic analysis to restore proper operation. This is a job for automotive engineers and beyond the scope of the reader of this forum. The motto should be don't fix it unless broken.
Old 07-11-2019, 10:17 AM
Mein Auto:
It was the business model , came fitted with tires 225/55/17 , with standard BMW 520i Suspension . Pics here .
Old 07-11-2019, 10:26 AM
mobilejo mobilejo is offline
Mein Auto: G06 X6
What?
You do not need "a computer dynamic analysis" when changing wheels & tyres. You need to ensure you get the correct offset & width of wheel (which will vary depending on the result desired) and correct tyre sizes to keep the rolling radius identical. i.e. You simply need to know what you are doing.
It is nothing that is beyond the scope of the average enthusiast, when making changes within reason.
Old 07-11-2019, 12:01 PM
Chabster Chabster is offline
Mein Auto: Audi
I think you can set your tires/rims configuration somewhere is the settings.
Old 07-12-2019, 09:35 AM
silberma1
Originally Posted by mobilejo View Post
What?
The 20" tires have shorter stiffer side walls which will cause a stiffer more bouncy ride compared with the original wheels. I would think that the springs and shocks are matched to the wheel/tire size. If the OP does not mind the worse ride they will work.
Old 07-12-2019, 09:49 AM
Mein Auto: G06 X6
Springs/shocks are not mated to the alloys chosen - M Sport suspension/standard suspension/adaptive dampers - those are the choices. For example, an M Sport suspension car could have 18's, 19's or 20's from the factory, there is no difference in the suspension.
There is no computer coding that can be/needs to be done to the suspension when changing wheels.
However, you are right that a bigger alloy with lower profile tyres will change the feel (stiffer yes, more bouncy no - the opposite). OP needs to accept that fact. But there are numerous factors to take into account.
Old 07-12-2019, 12:04 PM
gtfish gtfish is offline
Mein Auto: BMW, Porsche
Have the wheels/tires balanced again, that is my guess on the issues. Changing wheels and tires will affect the overall spring rate so the car could feel softer or harsher depending on the tires chosen. The wheel gap is a function of the overall diameter and not much you can do without changing out to different tires (sidewall heights) or actual suspension parts.
How many miles on the shocks?
Old 07-12-2019, 01:31 PM
BobRBob's Avatar
BobRBob BobRBob is offline
Mein Auto: 2017 540ix
A bigger fender gap implies a smaller total wheel diameter than with the original tires. I'm no expert but I would want replacement tires with the exact same outside diameter. A smaller tire means more rotations per mile and speedometer/odometer readings on the high side.
Current BMW
2017 BMW 540ix
Dark Graphite Metallic/Ivory
Prior BMWs
2014 BMW 535ix
Imperial Blue/Beige interior
2011 528i
Cashmere Silver/Black Dakota
2001 530i Sport (deceased)
Cosmos Black
Other
2018 Subaru Legacy 3.6R
1977 Corvette 383 Stroker
Old 07-20-2019, 10:07 AM
mrashton mrashton is offline
Mein Auto: G32 640i GT; F45 218i 2AT
The wheels you've fitted, assuming the same offset are within 0.2mm (front) and 6.3mm (rear) of a similar diameter so the rolling circumference of the wheel is nigh on identical to the 17" wheels you removed. I suppose the 6.3mm rear gap increase may be obvious.
As for you now having a bigger gap and based on the above 0.2mm/6.3mm difference you could lower the suspension as I'm sure many have done but the gap should be no different from your car had it been specified with 20" rims and tyres from the factory. As others have said, there is one suspension setup with different wheel combinations available.
Remember there is now a much narrower sidewall 123.75mm previously 85.75mm now (on the front wheel) so the drive is going to feel very different as the previous higher sidewall is going to be adding to the rebound capability of the suspension and this has been dramatically reduced with the new tyres.
If you are feeling vibrations now I would be going back to the tyre fitter to get them re-balanced as the larger rim/narrower sidewall of the 20" wheels is often quite challenging to get perfectly balanced.
I'd live with the car for a while to get used to the different driving experience as it will never be what it was with the 17" rims and tyres. But the car will look very good.
Here are the different rim and tyre sizes available as standard/optional factory fits:
G30 17" Tyre: 225/55R17 Rim: 7.5J x 17 ET:27
G30 18" Tyre: 245/45R18 Rim: 8j x 18 ET:30
G30 19" Tyre: 245/40R19 + 275/35R19 Rim: 8j x 19 ET:30 + 9j x 19 ET:44
G39 20" Tyre: 245/35R20 + 275/30R20 Rim: 8j x 20 ET:30 + 9j x 20 ET:44
Old 07-21-2019, 08:51 AM
PeterC4 PeterC4 is offline
Mein Auto: M550ix
Just re-reading your post are the rears 275/30/20? You may have a typo there. In any event, obviously its very important to comply with the specific options specified by BMW. Vibration can be caused by out of balance tires, a defective or bent rim (and that is very difficult to remedy with just a wheel balance), an out of round tire, or defective tire which on a run flat can happen if you hit a pot hole, or a suspension problem.
From experience, most of the time, a proper wheel balancing does it. If you have run flats, they can be a little more complicated because the sidewalls are very stiff to assist you when driving if you have a deflated tire. But I found the sidewalls can be slightly deformed after a constant pounding depending on road conditions, and the rim size.
From experience, I hate vibration in wheels and you have to be insistent to get it right and watch out for a bent rim. As to ride quality, I believe you will find that the bigger the rim, the less rubber on the road, hence you will feel a lot more road imperfections. Not much you're gonna be able to do about that.
2018 M550xi Black Sapphire
20", g30, rims, shock absorber, springs, tires, wheels
