Oil Level Sensor - Bimmerfest - BMW Forums
Old 11-25-2019, 10:38 AM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
Registered Non-OP
Mein Auto: 5wagon
Oil Level Sensor
Hello guys, quick question and hoping you guys will have an answer for me.
I am diagnosing my fathers z4 that we commute with a couple days a week. The check engine light is on and the two active errors are thermal oil level sensor, and, ambient temp sensor. I'm pretty sure both of them are faulty so I'm not doubting the codes... BUT I was wondering if the oil level sensor is something that would actually illuminate the CEL if faulty? I know I should replace them anyway, which I will.. But before addressing those, I want to make sure that the sensor is the culprit to the CEL since the Z4 is due for smog in January..
Thought?
TIA
-Usama
1994 325is (2006-2010) -- 1989 325i M50 Swap (2011 - 2014) -- 2001 525iT (2018 -Current)
Old 11-27-2019, 07:24 AM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Anyone? I just want to know if it's normal for a CEL to turn on for a silly oil level sensor? If so, I already threw the part in the Shopping cart on FCP Euro..
-Usama
Old 11-27-2019, 08:25 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Hi, could be a random event that triggered the CEL. if you are certain the oil level is correct you can clear the codes and see which code(s) come back.
[SIGPIC]
Old 11-27-2019, 09:40 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is online now
BeeemerBro
Mein Auto: X3 M54 150k
If the oil sensor light came on equalling the code (really the pic of the oil can) then change it...see,
https://www.bimmerfest.com/forums/sh...php?p=13172113
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 12-04-2019, 04:10 PM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Yeah, each time I clear the codes it comes back.. Looks like the engine is running lean as well, so it looks like there is a vacuum leak, or... (see below)
Thanks, I'll be making an order soon now to replace that level sensor.
I used the BMW scanner software to run the codes and I get the attached errors. These are the ones I posted about. But there are also a lot of shadow codes that include bank 1 and 2 lean codes. I just looked under the hood of the z4 today and noticed the vacuum hose connected to the brake booster seems choked and wonder if anyone experienced this problem? I would assume that this is the cause of the lean codes, but it's never that simple, right??
What could cause that vacuum hose to be under "suction" like that?
ID:	874463   Click image for larger version
-Usama
Old 12-04-2019, 09:53 PM
The brake booster system should hold vacuum after you shut down the car, so it sounds like the system is ok but the booster hose is collapsed and may need to be replaced.
[SIGPIC]
Old 12-05-2019, 08:02 AM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Yeah, I made the order through FCP Euro last night for the Oil Level Sensor, Ambient Air Temp Sensor, the Brake Booster hose, and an Oil Filter for a fresh oil change. Hopefully that'll get rid of all the codes and get this puppy on it's way to get smogged
-Usama
Old 12-05-2019, 10:58 PM
BeeemerBro
I hope this is the end but usually it is not...how many miles did you say? Most likely you've got to smoke test the thing but do report back with this preliminary results.
Sent from my SM-G531H using Tapatalk
Old 12-18-2019, 10:26 AM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
So I changed the above mentioned parts over the weekend, and everything went in nicely other than the temperature sensor, the wires were ripped up and had no more connection to plug into the sensor. So I cleared the codes hoping that I resolved all major issues that'll cause a CEL, but the stupid temperature sensor error is the only error I see and the CEL came back on.. Is that stupid sensor REALLY illuminating the CEL? I find this ridiculous.. The temp sensor is out on my e39 525i and no check engine light..
Is there something I'm missing here?
-Usama
Old 12-30-2019, 07:04 AM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Update: repaired wires for the temp sensor and reset the codes. Codes are gone and CEL did not turn back on.
-Usama
