2003 BMW 325ci Coupe 5 speed manual RWD VIN: PC99717
Jet Black w/ Black Interior & Sport package
Manual Seats w/ Seat Heaters
136,000 miles, 2nd owner
Asking $7500
Located in Orlando, FL Clean title in hand and will deliver to most parts of FL
Steering/Suspension/Brakes/Wheels:
BC Racing Coilovers w/ endlinks & adjustable front camber plates
Turner Motorsport rear sway bar
Turner Motorsport rear adjustable camber arms
Akebono pads front and rear
X5 E70 wheels 18x8.5
20mm spacers w/ extended lug studs
New tires all the way around
@125k the following were replaced w/ OEM Parts-
Driveshaft guibo bushing
Engine and Trans Mounts replaced
Lower control arm bushings
Steering joint bushing
Drivetrain All OEM Parts used:
Oil changes every 5k miles w/ Filter
Bosch spark plugs and fuel filter @ 100k
Starter and fuel pump replaced @ 100k
Updated gas cap
Radiator, expansion tank, cap, hoses, thermostat, water pump
Coolant pipes replaced under intake manifold
Oil Filter housing gasket and VANOS Line replaced
Oil Pan Gasket replaced
Drivers side fuel sending unit replaced
DISA Valve replaced
Interior:
Suede wrapped headliner, b-pillars, c-pillars
Black A-pillars
Suede wrapped rear deck shelf (faded)
M3 steering wheel and trim
Replaced shift knob boot & e-brake boot
Replaced armrest leather
ZHP weighted shift knob
LED lights for all interior lighting
AUX input cable in storage compartment
Airbag recalls performed/replaced
Exterior:
ZHP front bumper with fogs & brake ducts installed
Wrapped drip rail trims (showing age)
OEM Black M3 side mirrors
M3 trunk lip spoiler
Matte Black kidney grills
Umnitza angel eyes with relay harness to fade in/out when locking or unlocking
Smoked DEPO corners, blacked out fender lights
Smoked Angel Eyes LED taillights
15% tint all around 50% tint windshield
OEM Windshield and upper seal
The Bad:
Cracked armrest folding mechanism but works
Drivers window squeals sometimes but works
Shifter surround trim cracked
Power steering line seeping a little ($75)
Sunroof doesn't auto close sometimes
A few dents, scratches, roof and hood fading
This car has no mechanical problems and is a proven great daily driver. No leaks from the engine at all. No dash lights on. Never been in an accident or had body work.
<a href="https://ibb.co/yYfm9Hw">
Asking $7500
Updated gas cap
DISA Valve replaced
Interior:
Black A-pillars
Exterior:
The Bad:
