Cracked ignition coils. Use or not to use? - Bimmerfest - BMW Forums
Old 02-24-2018, 06:30 PM
TheWeej TheWeej is offline
Mein Auto: '11 BMW E92 335xi
I got some BOSCH ignition coils from a 328xi that intend to put on my N55 335xi. 2006-2012 coils i've heard are interchangeable and I will replace all of my coils with new ones. These coils were used for about 45K and they looked pretty clean. However 2 of 6 coils have these cracks on them and it seems like a no brainer answer to get a new one.
Would these cracks be considered a big hazard? Should I let them go? I haven't tested them yet but I want to know if pitting/cracking like this is a big red flag.
Dealership quoting 1k for a coil and plug replacement for all of them, I've got new sparks on the way and decided to pick up a buddy's coils and I will just do them myself.
https://i.imgur.com/XiqFS4P.jpg
Old 02-24-2018, 06:53 PM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
Why not just buy new coils ? You can get them pretty cheap:
http://www.rockauto.com/en/catalog/b...tion+coil,7060
Not even sure if -40 degrees is cold anymore ?
Old 02-24-2018, 06:57 PM
gbalthrop gbalthrop is online now
Mein Auto: 2007 328xi E91
Definitely DIY @ $25 per coil & $10 per plug
I was surprised to find that your 2011 N55 DOES have the same Bosch coils specified as my 2007 N52KP:
https://www.autohausaz.com/pn/0221504470
I had a similar chunk of rubber missing on one of my coils when I changed the plugs, and replaced that coil "just to be safe." I had a Bosch coil of the same part# so figured I would just use it -- OK to mix old & new if same part#. Just do NOT use Bosch & Delphi, mix & UNmatch.
THAT coil was NOT causing a misfire code on mine, so maybe not something to be worried about. You might be safe just to wrap that part of the coil/ plug boot where the insulation is missing with electrical tape (if high-temp tape). Just a matter of how much you want to pay for peace-of-mind & not having to redo the job in a year or so.
George
Old 02-24-2018, 07:36 PM
Thanks for the feedback and replies. Yeah DIY all the way.. pelican parts guides are great.
$10 bucks a coil is good but I was hoping to get away with these free hand me downs. Better safe than sorry.
And yeah I was trying to find out the main difference between these coils. Seems like the N55 ones have this metallic outer part as opposed to these rubber ones. How much of a difference does that make?
Thanks again though!
Old 02-25-2018, 07:14 AM
CALWATERBOY DUE CALWATERBOY DUE is offline
Banned
Mein Auto: 09 E93 335i somewhat mod
Yep.
You're smart to buy virgin coils! It's a BMW so money's no object.
bosch, coil replacement, delphi, engine, ignition coils, n54, n55, oem, plugs replacement, spark plugs, turbo
