Need blower motor help! - Bimmerfest - BMW Forums
Old 03-22-2019, 10:27 AM
frisbeeguy's Avatar
frisbeeguy frisbeeguy is offline
Mein Auto: 07 BMW X3, 98 QX4
How on earth do I disconnect the blower plug? This job is already 10 times harder than a VAG...lol
Learn more about your BMW from Radical9Auto!
https://www.youtube.com/channel/UCXN...Hw-og/featured
Old 03-22-2019, 10:32 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Use something pointy to push those little clips.
Old 03-22-2019, 11:33 AM
frisbeeguy's Avatar
What a pain in the butt. I got impatient and just cut the wires...there's a connection in the very back to disconnect now to put the new one in
Old 03-22-2019, 01:16 PM
frisbeeguy's Avatar
Jeepo, you had so much patience with this job...never been swearing so much until now...hope to never do this again...lol
Sunroof was way easier XD
Some stupid engineers designed this blower motor location/stuff around it.
Old 03-22-2019, 08:09 PM
LOL! Man I dreaded this job by reading about it, once I tackled it what breeze. I was like I have no idea why people are complaining about this so much. I did it in middle of January in the garage and it was freezing. Was like a hour and a half job if that.
Old 04-02-2019, 09:04 AM
frisbeeguy's Avatar
Just updating for those who want to do this job:
1) New Behr motor comes with pre-soldered wires to motor, so no ISO connector like in picture attached on a post here
2) Remove the cross-brace. It gets in the way
3) Ideally, remove/slightly detach the windshield cowl...it also gets in the way and is annoying
4) You NEED a magnetic reach tool. Get that BEFORE the job to prevent dropped screws into the HVAC box.
5) If you want an alarm, might as well do the job now.
6) Before starting, turn off recirculation
7) Long needle nose pliers are required to disconnect/attach the blower motor plug, which is NOT in the attached picture, the plug is recessed deep inside and unless you have squirrel hands, is hard to disconnect.
8) Don't be afraid to bend the plastic cover quite a bit, it has to be bent a lot anyway to pull it out along with working the metal straps away from it.
Old 04-02-2019, 11:10 PM
darknmy darknmy is offline
Mein Auto: 04' X3 3.0i
what's that?
Old 04-02-2019, 11:12 PM
did you remove the windshield cowl?
I have the "cool side" of the blower a bit noisy - thinking about removing it and greasing
Old 04-03-2019, 08:06 AM
44 Cents's Avatar
44 Cents 44 Cents is offline
Mein Auto: X-3
Frisbee..I love your #2. If we had dipsticks I swear you need to remove the brace to check the oil. Seems like everything I do that brace gets in the way somehow. Between that and the airboxes along the front I can get that all off now in less than 60 seconds lol. Dont get me started on the cowl thing Dark...my first time taking that off wasnt bad but trying to get it back in....I about threw it across the lawn. I sometimes feel one heartbeat away from becoming Grizwald and destroying the truck like a reindeer display! Thank God I work in medicine with patients all day buwhahahaha!
Fixed so far with help from here- plugs, coils, actuator gear, changed transfer case and diff fluid, replaced coolant reservoir/hoses, fixed pano roof, replaced windshield molding, replaced one/cleaned vanos solenoids, aux fan, VC, DISA, upgraded rotors and pads and numerous other little things like changing oil, cabin filter etc. Easily $6,000 savings vs dealer. ... BMWs lack DNA and viruses so I have no clue what Im doing.
Similar Threads
Blower motor doesn't work dharmabmw E60 / E61 (2004 - 2010) 32 12-07-2018 02:18 PM
Noisy blower - noise like something is stuck in fan paribest E90/E91/E92/E93 (2006 - 2013) 1 08-25-2018 06:01 PM
Ac blower not working Arce04 X5 E70 (2007 - 2013) 7 08-16-2018 05:54 PM
A/C Blower Motor Replacement daders F07 Gran Turismo (2010 - 2017) 11 08-15-2018 04:40 PM
I just fixed my 96 328i's blower motor final stage resistor erguy63 3 Series & 4 Series 0 09-12-2004 01:56 AM
