wiper relay location 2000 5281A - Bimmerfest - BMW Forums
Old 07-06-2010, 02:40 PM
mckaymike00 mckaymike00 is offline
Mein Auto: 528i 2000
Ok I have read most of the threads concerning this and it's not there! Under the drivers side cabin air filter is nothing but the brake stuff and the passenger side has the wiper fluid tank. Where else should I look???
I feel certain that it is the relay as the rain sensor/delay would work then stop as time grew it just would not work. All the time regular speeds would work. When ever it did stop a few hours later it would work again. Of course now it doesnt work at all!
2000 528i with rain sensor & premium & sport package
production is 9/99
HELP! Got laid off so I have to do this myself!
Old 07-06-2010, 07:47 PM
cn90 cn90 is offline
Under passenger's side cabin filter housing.
You might want to read this thread "Windshield Wipers don't work":
http://www.forums.bimmerfest.com/sho....php?p=4729485
Old 07-06-2010, 09:08 PM
I removed the passenger side cabin air filter housing in the engine compartment and the tank for the wiper washer was there! So is this inside the car on the passenger side or below the tank of windshield washer fluid?
Thanks for responding so quickly!
Old 07-07-2010, 08:25 AM
Found it! Thanks
Old 07-07-2010, 08:29 AM
Post a follow-up later.
Old 07-07-2010, 09:45 AM
Done! $36 and my wipers are working again! Thanks for your support - you saved me a couple of hundred dollars!
Old 07-07-2010, 10:02 AM
Please post your Part Number in case others need it in the future.
Old 09-27-2010, 10:17 PM
chadi's Avatar
chadi chadi is offline
Mein Auto: A car
Ok did some research and had a tough time finding the correct part, but here it is with a pic included. BTW 2000 528i with sports package and auto transmission.
Ordered from eactuning.com
61368384505 Multi Purpose Relay GENUINE BMW 1 $21.39
Relay is the tan one at bottom of pic.
Old 10-30-2010, 05:50 PM
Since it is important to show the difference between earlier models (1996-97) and later years (1998- etc.), attached is the pic that shows the difference:
Old 01-03-2011, 11:16 AM
mrsander mrsander is offline
Mein Auto: E34 525
Thanks a lot for the picture ! - I was going crazy trying to find the brown relay I should replace ! - Now concluding that I dont have that at all :-)
I did take apart the two purple relays and found the error ! - Bad contacts. Clean them and wupti - everything worked again.
Old 01-03-2011, 12:18 PM
Good job.
However, I don't recommend cleaning these relays at all because the purple relay is only $10 each, and yet they perform a critical function: what you don't want is the relays fail during heavy rain/snow, now you are talking about a crash that could have been prevented!
Old 10-10-2011, 04:49 PM
givip givip is offline
Mein Auto: 528i
relay numbers?
anyone have the part numbers for the K36 and K 37 relays? The two violet ones. Thanks. I would go pull mine and look but the car is 2 states away and I need to order them now.
Old 10-10-2011, 07:48 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I would think you can find them for your particular model year over here ...
- BMWfans phantom diagrams (1) & Realoem nominal prices by part number (1) & EACTuning prices by part number (1) & the most often recommended parts suppliers (1) & joining BMWCCA to lower parts costs (1) (2)
Old 10-10-2011, 08:08 PM
Mein Auto: 528i
Problem
Thanks for the sites. I had already checked several of them but the problem is that they don't show the relays where they are located on the car. They just have a "various relays" section. They are color coded but I'm not sure if the violet relay in the various relay section is the violet one shown and labeled as K36 and K37 in the picture. It shows a number of 61 36 1 388 911 but no where does it say this is the wiper relay --- only the colors seem to match. Anyone know? Is this the right one? Are the K36 and K37 identical relays? Thanks again
Old 10-15-2011, 12:26 PM
Mein Auto: 528i
still broken
I confirmed the violet relay (k36 and K37) are part number 61 361 388 911. They are both the same. I replace both but still have no wipers. I checked and have about 6vdc at the switch, when I turn the wipers on I can here K36 click but not K37. I have 11.5vdc all the time at one pin on K37 but no click ever. At the motor with the wiper switch on I only have 3.6vdc. Ideas??????
Old 09-14-2018, 07:21 AM
Consciousone Consciousone is offline
Mein Auto: 97 540i
Same problem, help!!
I realize this is a really old thread but I have the same problem. It's not the relays or the fuse. Did you get his fixed?
Does anyone reading this have any ideas?
528i, location, wiper, wiper relay
