2003 Z4 help. - Bimmerfest - BMW Forums
Old 05-21-2012, 05:25 PM
Anomic1 Anomic1 is offline
Mein Auto: 2003 BMW Z4 2.5i roadster
Unhappy 2003 Z4 help.
whats up everyone. well this weekend i made the stupid mistake of putting my lunch box with ice water in trunk. the water ended up spilling and getting into battery area. i didnt notice until my radio died speakers started to pop, then died completely. i dried and cleaned the area, but do to my dumbass mistake still dead....luckily its the only problem ive had...my question is...what is most likely damaged or what do i need to replace in order to get sounds back on? would appreciate any feedback thanks.
ID:	326564   Click image for larger version
ID:	326565   Click image for larger version
ID:	326566   Click image for larger version
ID:	326567   Click image for larger version
Old 05-21-2012, 08:05 PM
BU Z4 BU Z4 is offline
JUVENTUS
Mein Auto: Z
Amplifier died
Old 05-22-2012, 04:02 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
You fried your Amp. It is the flat black box in the battery area. Check your fuse's. Might of just blown a fuse if your are lucky. Good luck !
Old 05-23-2012, 05:10 PM
thanks guys
Old 08-12-2012, 12:13 PM
crosboe crosboe is offline
Mein Auto: BMW Z4
Same problem ;/
Hey, same exact thing happened to me except it was some cleaning soap that spilled in my trunk. I really think the battery compartment should have a snap on plastic lid that at least semi protects it...none the less it was still my fault. Everything in the car works find but speakers popped for a bit then died when I realized about the spill.
Did you make any progress fixing it up? Was it just a fuse, or did you have to replace the part, and were the speakers ok after? Thanks a bunch.
Old 08-13-2012, 08:11 AM
Trapper Trapper is offline
I'd rather by driving
Mein Auto: 2003 Z4 2.5 Titanium Silv
I just replaced the amp in my 03 Z4. I got a used one from A1euromotors in Florida. Just e-mail them your amp number to see if they have a replacment on hand. The cheapest solution i found.
E-mail [email protected]
Old 08-13-2012, 08:55 AM
Hey sorry for the late reply crosboe. I didn't resolve my amp issue yet. I got so fustrated I gave up for the moment, but need to do something about it asap! I hate my sounds rightnow...my speakers sound horrible volume can only go so high, no bass and sounds horrible!....do you know if the amp I have installed on 03 not 04 has a fuse? I've seen diffrent years with fuses on outside of amp,but there isn't one on the outside of this one..I haven't replaced because its too damn expensive for a stock amp. I was hoping to upgrade with custom harness,but that fustrated me further.
