Diesels- Have you ever had exhaust leak into your cabin? - Bimmerfest - BMW Forums
Old 01-31-2014, 11:56 AM
eagerpooch eagerpooch is offline
Mein Auto: 2010 BMW X5 35d
If so, this is a common problem that BMW needs to address in BMW X5 35d (E70) and other diesels. It is an EGR cooler or EGR Valve issue leaking exhaust in the engine compartment and blowing exhaust through the vents.
File a complaint here to push for a recall. it takes 30 seconds. just have your VIN ready
http://www.safercar.gov/Vehicle+Owners
I know i have been painting the forum with this issue but I dont want to hear about a baby who died in the car or a mother who got carbon monoixide poisoned and ran off the road.
Old 02-03-2014, 01:06 PM
dzampi dzampi is offline
Mein Auto: 2010 BMW X5d
In Canada there is a recall on it...they just did mine...
Old 02-03-2014, 01:14 PM
Really? Are you out of warranty and they did it anyway?
Old 02-03-2014, 01:41 PM
smyles smyles is offline
Mein Auto: X5
Originally Posted by eagerpooch View Post
..File a complaint here to push for a recall.
Recall of what exactly?
Do you realize there are multiple possible causes of exhaust leak?
EGR valve
EGR cooler
EGR "plumbing" (so to speak)
Exhaust manifold
Gaskets
Any part of exhaust piping
Turbos
etc etc
Some of these items BMW has already addressed via recall campaigns, widely advertised or rather quiet, and some deem rare enough to ignore (and make $$ in the process). In case of EGR cooler, to my understanding they - BMW - believe it's the bracket that causes cooler cracking, and there's a recall for that.
Old 02-03-2014, 02:09 PM
EGR valve to be exact....
Before that they had to tighten the exhaust manifold...
and yes I'm out of warranty....
Old 02-04-2014, 07:58 PM
aiwapro aiwapro is offline
Mein Auto: 2013 X5 35d
I have an occasional Diesel smell in the cabin, and also the smell of windshield washer fluid, when I use it. It's not what I expected for a new vehicle.
Old 02-04-2014, 10:18 PM
bossboy302 bossboy302 is offline
Mein Auto: 2013 Ford F150
BMW has addressed this issue. There is a "campaign" (a sort of voluntary recall) that adds an additional support bracket to the egr valve to eliminate vibration-induced cracking (and leaking).
Not to be a nudge, but this topic is very well covered in multiple threads on this very forum.
Check it out.
I measured twice, cut three times, and it's still too short!
2012 X5 35d
2013 Ford F150
1967 911S
Old 09-26-2014, 09:29 PM
HerrDiesel HerrDiesel is offline
Mein Auto: 2014 328d
I may be having this problem with my 2014 328d it's either exhaust or a fuel leak or some sort of gas escaping in the engine compartment when you say diesels all models all years?
Old 09-26-2014, 09:34 PM
Sorry I have now read all the threads could the egr valve still be an issue in a 14 328d hard to believe but the air in the cabin through the vents is bad
Old 12-07-2019, 11:10 PM
cameron001 cameron001 is offline
Mein Auto:
Same issue. Found the leak by spraying soapy water over the exhaust parts. The leak comes from the expansion connector near the top right elbow on the EGR cooler, just before the connection to the intake manifold.
There was staining around the area also.
I used high temp silicon to temporarily fill the gap. Waiting for BMW to cough up for a replacement.
cabin, carbon monoxide, diesel, egr, exhaust, fumes, smell, valve, vents
