Roll backwards in drive - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X3 M, X5 M, X6 M, Z3 M & Z4 M > F85 X5 M and F86 X6 M (2016 - Current)
The BMW X5 M and X6 M are high-performance derivative of the X5 and X6. Introduced at the 2014 LA Auto Show and appearing in dealerships in 2015. Both modeles are powered by BMW's S63tu twin turbo charged V8 making 567 HP and 553 lb-ft of torque, the most power for any BMW xDrive vehicle.
Old 02-08-2016, 05:21 AM
cmyx5go cmyx5go is offline
Mein Auto: '16 X6 ///M
Good morning boys and girls.
Sometimes, in the time it takes me to go from the brake to the gas - say at a light - I roll backwards ever so slightly. This morning, it was more than ever so slightly. So much so, my nephew looked at me like I lost my mind and said what the hell was that. I wasn't even on an incline. Me no like. Am I going to have to start driving with two feet? If someone was up my butt, I would have rolled into them.
Anyone else?
Old 02-08-2016, 08:34 AM
BMWSRT BMWSRT is offline
Mein Auto:
Shouldn’t be happening. I would take it to the dealer and have them sort it out. In the meantime use the auto H feature so you dont rear end anybody
Old 02-09-2016, 10:16 AM
XZLR8's Avatar
XZLR8 XZLR8 is offline
Mein Auto: ///M850i
That's the way the new transmission works. I push the auto-hold button now as a matter of habit, which resolves the issue and makes it work more like a traditional automatic.
'20 BMW X6 ///M50i | ManhattanGreen/Black
'19 BMW ///M850i | DravitGrey/Black
'18 BMW i3S REx | MineralGrey/DalbergiaBrown
RETIRED: '18 M550i, '17 X6 50i, '17 X5 50i, '16 X6M, '16 750i, '15 X4 35i, '14 328xiT, '14 X6M, '14 X6 35i, '13 650xiGC, '12 650xi, '11 535xi, '11 X6 50i, '09 750i, '09 328xiT, '08 650i, '07 750i, '07 X5 4.8i, '06 650i, '05 745i, '05 325xiT, '03 745i, '02 745i, '01 325Cic, '01 X5 4.4i, and on...
Old 02-09-2016, 05:26 PM
Mein Auto:
There should be a couple seconds before rolling backwards... Not immediately from brake to gas pedal...
Old 02-09-2016, 08:34 PM
awesoM awesoM is offline
Mein Auto: X5M and M4 Convertible
I concur, they new transmission treats it more like a manual vs an automatic, just be careful and don't forget to put your foot on the brake or engage auto-h when you are at a stop.. especially on a slope.
Old 02-09-2016, 08:46 PM
XZLR8's Avatar
Mein Auto: ///M850i
Yeah, exactly. The good thing is that you can see it light up on the display when auto-hold is actually engaged and working.
Old 02-10-2016, 04:59 AM
Thanks all. I read on another forum that there is a 3 second delay. It sure felt faster than that, I'm quick from brake to gas when the light changes. The bizarre part is that I wasn't on an incline. I guess I'll be using the auto hold.
When I read the manual the explanation was somewhat confusing as far as activating and deactivating. It said to apply brake to deactivate, but then it said when activated it will engage after you come to a full stop. I used it last night. You just press it and forget it. Is that correct?
Old 02-10-2016, 06:02 AM
XZLR8's Avatar
Mein Auto: ///M850i
Yep. The only thing that sucks is you have to press it every time you start the car.
Old 02-11-2016, 04:44 AM
Thank you!
Old 03-24-2016, 11:32 AM
PhantomCypher PhantomCypher is offline
Mein Auto: 550i GT Maser Ferrari FF
The rolling-back is definitely normal behavior for the car. I kind of like it because it gives this big sport 'ute a manual transmission feel.
You gotta just apply the brake or use the Auto-H function behind the parking brake.
Old 03-24-2016, 12:00 PM
Thanks Phantom, I had to learn the hard way. I never had a need to use the Auto H before. It is now an automatic thing, instead of taking off the parking brake, I just put on the auto hold.
I have however, rolled both backwards and forwards when Auto H is activated. It's a bit unnerving. Not sure why this happens. It has happened to me when shifting from drive to reverse, and reverse to drive.
Old 01-22-2017, 03:24 PM
jettie1767 jettie1767 is offline
Send a message via AIM to jettie1767 Send a message via Yahoo to jettie1767
Mein Auto: 2012 BMW M6
All M transmissions behave like that. It behaves like a clutchless manual.
Current stable:
'18 BMW Alpina B7 Alpina Blue
'17 Toyota Prius Prime Plus Millenium Silver
