2008 535i CATALYTIC CONVERTER HELP - Bimmerfest - BMW Forums
Old 03-02-2017, 03:46 PM
1ofakind 1ofakind is offline
Mein Auto: 2008 E60 535i
Hey Guys
so I am having troubles with my cats, I believe they definitely need replacement, I am at about 120k miles.
Please keep in mind I know nothing about the cats on these
so the problem I am having is, these are the parts numbers
18307565330
18307565331
Those are for the replacement cats.
the part number that my mechanic took a photo of is 7565334. So I am aware that this is the part number for the "exhaust manifold headers" with O2 sensors
Are these the same parts? As in if i buy refurbished exhaust manifold headers does that come with the cats as well?
Sorry, not trying to sound dumb... but everything I Google in terms of cats for my car come up 7565330/7565331 and if buy that part, am I technically buying an entire "exhaust manifold header?"
Some help would be needed.
Thanks guys!
Old 03-23-2017, 07:29 PM
bump
Old 03-23-2017, 07:43 PM
impac4000 impac4000 is offline
Mein Auto: 2008 BMW 535i
Did you read for codes? Is so what comes up? I've never heard anyone having problems with cats on N54 engine unless they r clogged, what are the symptoms?
Exterior -- Full Umnitza Bodykit, 19" F10 wheels, rear roof spoiler, M5 trunk spoiler, H&R Sport Springs, BMS 10mm front and 15mm rear spacers.
Engine-- FBO, JB4, MHD BackEnd Flash
Old 03-24-2017, 07:17 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
Right... IF the cats need replaced (I am doubtful), something else needs fixed
Old 05-10-2018, 12:40 PM
evenfall evenfall is offline
Mein Auto: 2006 BMW 530i
I know this thread is a year old but I was wondering if there has been a solution.
I've had the check engine light for both cats being bad for 3 years already. No symptoms so far besides the CEL but I am totally not sure what to do when it comes to the point where they need to be replaced. I believe they are integrated into the intake manifold so the OEM solution would be prohibitively expensive. Has anyone had any luck with aftermarket parts? I have researched extensively and was not able to find much. Would appreciate any ideas.
Old 05-10-2018, 12:43 PM
NoQuarter's Avatar
Well... the intake manifold is where the air comes into the engine, so no cats connected there.
What model car do you have?
Old 05-10-2018, 12:56 PM
Sorry, I think I meant *exhaust* manifold. I have a 2006 530i.
Old 05-10-2018, 01:03 PM
NoQuarter's Avatar
How did you read the codes and have you ever cleared them to see when they come back?
Old 05-10-2018, 01:16 PM
I had them read at both Autozone and an independent BMW mechanic and they both agreed on both cats being bad. I've had them cleared and a couple of times they went out by themselves but they always come back.
The indie actually told me he's seen the CEL with these codes to go on for many years without producing any other symptoms and recommended to do nothing until the cats actually start causing trouble. I just want to have some kind of a plan when that does happen.
Old 05-10-2018, 01:23 PM
NoQuarter's Avatar
If you don't require emission testing then have them cut out and replaced with pipe?
You still have 2 more cats in the exhaust.
I would have the O2 sensors replaced first.
Old 05-10-2018, 01:26 PM
OK thank you, I will keep that in mind. I actually talked to a few exhaust/muffler shops about this issue but neither of them would touch this particular model.
2008, 535i, cats, e60, exhaust
