F30 / F31 / F32 / F33 / F34 / F36 (2012 - current)
The sixth generation BMW 3 Series Sedan F30/F31/F34 and the first first generation 4 Series Coupe F32/F33/F36. Get the latest 3 and 4 series pricing from our ordering and pricing guide sticky thread. |
Temperature sensor at radiator outlet
Hi everyone, i have f30 328i with n26 engine and recently plugged the obd scanner to check for errors and got bmw specific code: 10A208 Temperature sensor at radiator outlet, signal, stationary. Also i checked the same error with another obd scanner which gave me generic fault code: P00B4 Radiator Coolant Temperature Sensor Circuit High.
I checked with voltmeter the Voltage of the sensor connector and got 5V. Maybe someone can help me with that? Is the sensor gone bad? SHould i repace it with new one? I will really be thankful if someone could help. |
Sponsored Links | ||
Advertisement | ||
Very often temperature sensors are temperature sensitive resistors / thermistors.
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness. (The Works of George Santayana p. 65) Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it. |
Clear code and see if it returns.
Check connection for corrosion. Check resistance of the sensor with DMM. Post measurement. 0 or infinite resistance would indicate a bad sensor, but an out of range signal would cause code also. |
Advertisement | ||
Thanks for your replies, i cleared the codes, cleaned the connections, also tried to measure the resistance, there was no 0 or infinite value(about 750Ohm on 70 degrees) so i assume problem was in poor connection, will check again and post updates.
Thanks. |
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
