Cali Smog & my 2012 X5 35d - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 08-23-2019, 12:26 PM
netcool netcool is offline
Mein Auto: 2012 X5 35d
Hello,
Looking for some clarifications if possible. Been reading the forums and I got analysis paralysis.
Been having some fun trying to pass smog and I think I'm close however I can't figure out the following:
1) Can my 2012 X5 35d pass smog test with the " PM Filter " still not set? Talking to various shops / smog testers and reading various bits on the net - apparently yes it can. One SA @ SM BMW said it won't pass as it is mandatory for " PM Filter " to be set.
I'd guess that if I can pass with this not being ready there is no point to keep reading below?
2) I had the EGR cooler replaced and then was left to drive the car so all the various monitors set. all did except for the " PM Filter ". I'd say I've managed to put about 400 highway miles and no love from the monitor. Apparently " just drive it " is the key but fear of other " stuff " having gone wrong made me borrow a plain obd reader and a Carly to see what else might be broken and found:
From the reader:
  • P2201 - NOX Sensor Circuit Range / Performance Bank 1 Sensor 1
From Carly:
  • 474C - Exhaust fluid error
>> this one is an old one as the dealer serviced this - so likely just not cleared after service? probably not a problem.
  • 4B6A - Nox sensor before denox cat - Plausibility
  • 4C7C - Reducing agent metering valve, activation
  • 46B4 - NOX Sensor before denox cat plausability nox
Anything in this list that could prevent the PM Filter monitor to set?
TY!
Old 08-23-2019, 01:15 PM
floydarogers's Avatar
Pedant and Curmudgeon
All of those are downstream in the exhaust from the DPF. So I would guess that they have no effect on the DPF stuff.
I would guess that, for whatever reason, no regeneration has yet occurred. My 335d does one about every tank (500 miles or so). You might try to force a regen with carly and see what happens to the pm filter.
Old 08-24-2019, 08:29 AM
Sabersix Sabersix is offline
Mein Auto: 2011 335d M-Sport
My guess is you need NOX Sensors replaced. Should be covered under extended warranty.
https://www.bimmerfest.com/forums/sh...d.php?t=916576
Old 08-24-2019, 11:27 AM
FredoinSF FredoinSF is online now
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
+1 on above and check if what parts on your car may have coverage here: http://www.bmw-rp.com/production/bmw...bmw_portal.nsf
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 10-12-2019, 11:07 PM
SoCalOC SoCalOC is offline
Mein Auto: 2011 bmw 335d
TPMS Light On
Hey guys,
Does anyone here knows if I could pass smog with my TPMS warning light on ?
I donít have any SES light on at all but only the TPMS light keeps blinking and gives me warning sound. The dealer advised to rotate my tires and possibly replaced the sensor.
I just want to know if I could pass smog and if the TPMS light would prevent me to pass ?
This might be a silly question. Thanks
Old 10-13-2019, 08:13 AM
ghpup's Avatar
ghpup ghpup is offline
Glfbggy
Mein Auto: 18 X5d , 14 535xd, 00 MZ3
Originally Posted by SoCalOC View Post
Hey guys,
It has been a while since I had to smog a car in CA (not since '92), but I do not remember the inspector getting in the vehicle to notice any of the warnings. If they do, perhaps they will fail for safety issues, but the TPMS in the tires has nothing to do with your emissions systems.
GLFBGGY
'00 MRoadster,
'00 528 now in other hands,
'07X3si now in other hands,
'14 535d XDrive,
'18 X5 35d In break-in...
Old 10-13-2019, 11:41 PM
Oh yea thatís what I was thinking thanks for that confirmation
35d, ca, california, diesel, egr, egr cooler, smog
HTML code is Off
