2007 Bmw 328 xi wheel problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 11-14-2019, 05:46 AM
Gianvmo Gianvmo is offline
Send a message via ICQ to Gianvmo
Mein Auto:
Yesterday my right rear tire popped in a curve while it was raining and I spun into the sidewalk and my rear left rim cracked, I need to get a new wheel but my wheel hub looks bent inwards, does anyone know what component could be broken?
ID:	872093   Click image for larger version
ID:	872095   Click image for larger version
Old 11-14-2019, 06:19 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
You can see in the second picture that the center part of the wheel broke from the main part of the wheel. You need a new wheel.
Old 11-14-2019, 06:27 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Good Lord, you broke out the entire center of the wheel?! Either those are some seriously cheap-a$$ M3 replicas or I don't even want to know the impact speed.
Regardless, there are five suspension links back there to support and locate the spindle. Any one or more (probably more) of them could be broken or bent. With an impact like that--in a direction the suspension is not designed to absorb--there is also the possibility of damage to the shock absorber, axle, and/or final drive. There's also a small but non-zero chance the anti-roll bar was bent and/or ripped from its mounts.
You need to get the car on a lift and fully inspected, including the subframe, by someone who knows BMWs. This is not a DIY repair unless and until you understand what you're up against, and regardless you will need a four-wheel alignment afterwards.
Good luck.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Old 11-22-2019, 02:05 PM
Zeichen311's Avatar
Originally Posted by eliotra View Post
You need to get the car on a lift and fully inspected, including the subframe, by someone who knows BMWs. This is not a DIY repair unless and until you understand what you're up against, and regardless you will need a four-wheel alignment afterwards. [[links removed]]
Die, spammer.
BMW CCA
Old 11-22-2019, 02:18 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Ban hammer applied.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
