02 325i random CEL and rough idle - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 11-13-2019, 07:39 PM
alexgmzz alexgmzz is offline
Mein Auto:
Hi all. I have an 02 325i. It had really bad idle and misfires. I replaced spark plugs, cleaned throttle body, ran sea foam through intake, swapped coils to see if misfires changed but didn't so seems could are good and it ran much better. However, it still had rough idle and CEL P0171. It ended up having a few vacuum leaks, I got those fixed. It now runs smooth BUT every now and again I'll get a rough idle at a stand still or while driving and CEL comes on. I check codes and I get the same P0171 among others. All related to misfires. Anyone know how it could run smooth for 2 days then suddenly have a P0171 with rough idle then 10 minutes later run smooth again??
ID:	872069   Click image for larger version
ID:	872071   Click image for larger version
ID:	872073   Click image for larger version
ID:	872075   Click image for larger version
ID:	872079   Click image for larger version
Old 11-13-2019, 07:50 PM
Mein Auto:
Forgot to mention I did a DIY smoke test to find vacuums - I may have missed one but still don't understand how it could run fine for several days then suddenly start sputtering. I also replaced the DISA O ring which was almost gone so definitely had a vacuum leak at DISA among others I found on brake booster hose.
Old 11-14-2019, 06:20 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
The only way to find all of the vacuum leaks is to professionally smoke test the intake. Find a reputable indie shop that specializes in bimmers at www.bimrs.org.
