RaceChip GTS Black Opinions - Bimmerfest - BMW Forums
Old 12-24-2017, 03:06 PM
550iDPE 550iDPE is offline
Mein Auto: 2011 550i
Hi there
new to the forum and a new bmw owner - any one out there have a newer model racechip box tuner (GTS black)on their car. Would like your feedback on if its a good purchase or if other competitors offer a better product
thanks
Old 02-14-2018, 01:39 PM
scottrobpowell scottrobpowell is offline
Scott Powell
Mein Auto: 2008 M3
Did you buy it? How do you like it? I just ordered Racechip GTS Black for my 550xi
Old 02-16-2018, 12:57 PM
notlkk notlkk is offline
Mein Auto: 228i
Make sure you share your experience here once you install it. Good luck!
Old 03-06-2018, 09:20 AM
Mein Auto: 228i
Did you install it? How was it?
Old 03-06-2018, 02:17 PM
535i_Biturbo 535i_Biturbo is offline
Mein Auto: '10 535i Msport
What power does it advertise for the n63 550i?
Old 03-06-2018, 03:15 PM
Scott Powell
Mein Auto: 2008 M3
I have not received my Race Chip yet, it got lost in shipping. I have a claim in with UPS. Soon as I get it, I will write a review.
Old 03-06-2018, 03:17 PM
Scott Powell
Mein Auto: 2008 M3
Up to 78hp, 86 lb-ft
Old 03-08-2018, 09:25 PM
PeteZ06 PeteZ06 is offline
Mein Auto: A car
I installed the GTS Black on my 535D a few weeks ago. Super easy. Definitely can tell a difference.
+50hp/+70tq for mine
2001 Corvette Z06 Speedway White .. 580rwhp
2008 Suzuki B-King .. 190rwhp
2014 535D RaceChip Tuned
2014 328xi wife
2003 4Runner Lifted and Fully Armored
Old 03-15-2018, 10:40 PM
Mein Auto: 228i
How do you know you gain 50hp+? What tool do you use?
Old 03-17-2018, 02:47 PM
TShoot's Avatar
TShoot TShoot is offline
Mein Auto: 2011 535ix
I run an older Racechip Ultimate on my 2011 535xi . How is the "GTS Black" supposed to be different?
Old 03-17-2018, 09:17 PM
Mein Auto: A car
Thats their claim
2014 328xi wife
Old 03-17-2018, 10:12 PM
hufington's Avatar
hufington hufington is offline
HUFINGTON
Mein Auto: '18 MB E63S
I have the Racechip Ultimate on my '16 550. Solid product and definitely worth trying. I had it on my previous F10 535 as well. Similar gains on both.
18 BMW F15 50i M Sport - 4.4 L 330 kW (445 hp) Fully Loaded
16 BMW F10 550xi - 4.4 L 330 kW
13 BMW F10 535i RWD - 3.0 L 221 kW
07 BMW E64 630i - 3.0 L 200 kW
03 BMW E65 745i - 4.4 L V8, 242 kW
98 BMW E39 535i - 3.5 L 183 kW
95 BMW E34 540i - 4.0 L V8 210 kW
89 BMW E30 M3 147 kW
18 MB E63S
17 MB C217 S550 4MATIC Coupe
15 MB W222 S550 4MATIC
10 Infiniti G37x Sedan
09 Mercedes C 350
08 Infiniti G35x Sedan
04 Mercedes CLK 350
01 Mercedes C 230
Old 03-20-2018, 02:17 PM
d_stew d_stew is offline
2011 550i xDrive mSport
Mein Auto: 2011 550i xDrive mSport
I've had the GTS Black on my 550ix + MSport for a couple months now.
I know many of you will want numbers, but -- I HAVE NOT PUT MY CAR ON A DYNO!! I have no measurements to offer. I only have anecdotal information.
It's a fairly easy install, although the installation instructions from the company leave a LOT to be desired! Even talking with support, they can't tell you where the cables connect. I had to take a light and look around myself. They offer pics of a VW engine compartment, which looks nothing like what's under the BMW bonnet. Be careful removing the plugs, or you'll break the plastic clip that holds the plug in the connector and helps seal against moisture.
Adjustments will take some amount of trial and error. Setting 5 seems to work really well. Settings 6 & 7 cause a lean mixture, so it's best to avoid long term use if you get the same error codes. The symptoms are that it will lack power uphill when the accelerator is mildly engaged. After a few seconds of power loss, you'll get the dreaded Drivetrain Malfunction. On setting 5, the vehicle has a much better pedal response (still not perfect, but it helps a lot) and you do get more power on the top end, too. On setting 5, I don't think I'm getting the additional 78hp, but I wouldn't be surprised to learn I'm getting an additional ~50hp. Driven moderately, you do get slightly better gas mileage. I don't drive moderately. I enjoy my horses working hard, when I need to move through traffic.
I have not tried settings 0-4.
The bypass plug does work.
I'll try to take some pics of my install, and the location of those pesky connectors to plug in to.
Once you install a couple times, it only takes 5 minutes to install with cable ties and remove. I remove mine when I take it to the shop, simply because I don't want any pushback on warranty repair.
Anything I didn't cover? Just ask!
2011 550i xDrive MSport
Old 03-20-2018, 03:37 PM
IRR IRR is offline
Mein Auto: 2014 550xi M Sport
d_stew a couple of quick questions.
1. Was it worth the money to install it?
2. What's your opinion on the dealership being able to tell you had it installed even though you removed it before service? Seems like there's debate on whether they can tell.
Old 03-20-2018, 09:26 PM
Worth is a funny thing, and tends to be relative to your financial situation. It was worth it to me. I have a much nimbler car, and it feels moderately more powerful.
I honestly do not know if a dealer could tell, but I have a couple thoughts. First, let me preface them. I'm not a mechanic, I just understand mechanics. I'm just a journalist who researches everything, both at work and home.
In my particular case, I have an extended warranty, so I don't think they care much about this chip. I only remove it before a dealer visit because it's relatively simple for me to remove and reinstall.
To be able for a dealer to tell, I believe they would need some secret error code getting tripped, which only their reader could see . While I don't doubt this could be done, I think we would all know about it, and it wouldn't serve much of a purpose, other than to purposefully look for any reason to void warranty. BMW doesn't strike me as a company looking to void warranties, simply because someone wants a more power from the drivetrain. I just think they have bigger fish to fry. There are so many other things that have a much bigger effect on engine life, like regular oil changes.
All that said, I could be wrong about all of it
Old 03-20-2018, 09:54 PM
igonz421 igonz421 is offline
Mein Auto: 2012 BMW 535ix F10
d stew thanks for your input. I just installed the Racechip GTS today and I am trying out different settings. I started with map 7 and I it pulled pretty good mid range. A little bit of lag when I floor it from stop, maybe the ECU is trying to figure things out. Then at mid range the car takes off. I have a 2012 535IX and I could almost swear that the car chirped when I floored it. Something very uncommon for my AWD. So far I'm satisfied with the chip. Thanks for info on map 6 and 7 running lean. I'm just trying to figure out which map gives me the best performance(hp/tq).
Old 03-20-2018, 10:01 PM
Your'e welcome!
It's going to be a much different experience, I would imagine, for you and your 535ix. My car runs lean, but you could experience something entirely different, since mine is a completely different engine.
You'll notice small differences on each setting. I'm still playing with different settings a bit, because some of the differences are subtle. While moving from one map to another, you may not notice much power difference, but you might notice better gas mileage. You'll also notice power differences at higher speeds, as opposed to off the line.
Good luck playing with the settings!
Old 03-21-2018, 03:45 PM
It seems likes it's still almost like the BMS N63 JB Stage 1 in the gains department
Old 03-25-2018, 01:21 PM
heliskiier heliskiier is offline
HAVOC 2 YOU
Mein Auto: 428xi Coupe
I see a Racechip one step up for the 2.0T for about 40HP/TQ on the net. Is is legit or just hoohaa? Just looking for a bit extra ooomph. Nothing exotic.
Old 03-25-2018, 01:48 PM
I can't speak to the accuracy of claims, because I didn't dyno my car, but my butt dyno tells me I have quite a bit more oomph, and I am getting better gas mileage, too. I haven't had a chance to measure over time and conditions (grade, wind speed/direction, temperature), but I have noticed a tank goes a bit further than it did.
The question everyone wants an answer to it, "is it worth it?" For that, I can only say it was worth it to me.
Old 03-25-2018, 02:47 PM
One week with the Racechip GTS on map 7. Definite difference with no issues on my 535ix F10. You will find the ooomph your looking for. I don't dyno but my wife's been complaining more about my driving.
Old 03-25-2018, 03:25 PM
Bwahahahaha! That's all the proof we need. When the little lady starts griping more, you know the chip is working!
Old 04-12-2018, 03:29 PM
HAVOC 2 YOU
Anyone here with one on a 428I? Not sure how good 50HP would be for my stock ride's ability to stay in one piece. I know the motor will be fine, but the rest of the drivetrain? I'll take any answers about any BMW with respect to wear/damage to other parts of the drivetrain. Don't wanna mess this thing up. I'm thinking that this car can easily handle another 50-75HP. Heck, my Camaro handled 125 extra just fine on the stock clutch and differential. Even ran an 11.5 on her with zero issues.
Old 04-12-2018, 03:41 PM
I can't imagine that would put an undue strain on the drivetrain. Now, if we're talking 100hp, I'd begin to make inquiries. Hopefully I'm not foolish here, but I think you'd be well safe to add it.
Old 04-12-2018, 06:18 PM
HAVOC 2 YOU
Good I feel OK with the GTS tune now. I didn't really think it would put my ride in danger, but we can never be too careful with stock rides. I'll go with 5 and see how it works out. Love the power now and going to super love 285. This car is a stud on a 2 turbo. I'm almost, but not quite, starting to lose my faith in 358 cubic inches of V8 love.
