Fault Code help - Bimmerfest - BMW Forums
Old 02-13-2019, 01:45 PM
Stephenkarl Stephenkarl is offline
Mein Auto: 2011 BMW X5 35D
Fault Code help
Hi all,
I used my bluedriver to scan my 2011 x5 diesel, and a couple codes popped up. The first is p2457 EGR Cooler "A"; the second is 2E3D "Interface EWD-DDE".
As I understand, the first could be related to a few things up to and including the EGR Cooler being replaced. My coolant thermostat is not reading above 82C, so I think the thermostat is shot, which (again, from my understanding) can lead to various hiccups in the emissions/EGR/DPF areas.
I'm not really sure what to make of 2E3D. Identifix shows it as a nox sensor, but the EWS-DDE has to do with the immobilizer/CAS, doesn't it? Comfort Access has stopped working on my car, so I'm a bit at a loss and hoping that I might be pointed in the correct diagnostic direction.
Thanks!
Old 07-03-2019, 01:23 PM
Busy_Dad Busy_Dad is offline
Mein Auto: X5D
Follow up
Did you manage to solve the problem? I have the same codes on my X5 35d.
Old 07-03-2019, 04:41 PM
ard ard is offline
Resident Curmudgeon
Clear the codes...drive...see what comes back. That is assuming there are zero other symptoms
Low battery/low voltage can sometimes cause spurious module comm faults, but see if a clear an re-read doesnt bring up better info. Or nothing
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 07-17-2019, 09:43 AM
Mein Auto: X5D
X5d Codes
Prior to the clearing, the engine would cut out under acceleration and multiple codes would show up including injector bank 2.
Now after clearing, the following codes show up
2E3D
452A
4BCC
E598
E0DA
Similar Threads
Lots of error codes on private sale car...concerning? afeudale F10 / F11 (2011 - 2016) 5 10-01-2018 10:09 AM
530xi rough idle ANY ADVICE Matt2408 E60 / E61 (2004 - 2010) 5 06-01-2018 06:53 PM
Recently had Rotors/brakes done all 4, 3 weeks later brakes stuck/ ABS won't benspie X5 E70 (2007 - 2013) 26 03-28-2018 07:12 PM
