Are the jack pads supposed to fit snug in the jacking point? - Bimmerfest - BMW Forums
Old 07-09-2019, 10:40 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Bought some new jack pads and jacking points. The Click image for larger version
ID:	857579pad rectangle is smaller than the jacking point rectangle. Is this how it is designed or should it be snug?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 07-09-2019, 10:55 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
That rectangular pad only goes on the side of the car. One front, one back - 2 on each side. There are tabs on the black thing in your picture that fit into the side rails. There is no pad for the front jack point, only a piece of steel protruding down a bit.
Old 07-09-2019, 11:17 AM
Thanks. I understand that. My question is that the rectangle on the jack pad is much smaller than where it would sit on the jacking point. Is this typical or should they be the same size so there is no play?Click image for larger version
Old 07-09-2019, 12:18 PM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
never used the circle pad, always just whatever is on the end of my jack. I think the factory jack inserts into that and is more snug.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 07-09-2019, 12:34 PM
Yeah. Iím not liking the fit of these. Both made for X5. If itís not snug it seems dumb to use. Time to return.
Old 07-09-2019, 01:09 PM
deroy deroy is offline
Mein Auto: X5 e70 4.8
Mine fit (almost) snugly. Hard to judge scale but it seems your new jack points are larger than my BMW originals.
Verzonden vanaf mijn iPhone met Tapatalk
Old 07-09-2019, 01:43 PM
The new jack points are exactly the same size as my old ones. The jack pad is smaller. Maybe there is more than one size jack pad adapter for BMW.
Old 07-09-2019, 03:35 PM
twh twh is offline
Ok...I have a couple of those jack pad things. The ones I have fit snugly and have a small rubber thing on the ends so they can stay in place even with no jack under the jack pad. But, I don't think it matters at all. As long as it fits in the hole more or less, it is fine. I also use small pieces of 1/2" (or may it is 23/32") plywood. I cut them to fit exactly in the well of the car's pad. That's fine too.
Old 07-11-2019, 03:05 PM
Looking online, they donít all state the measurements of the circle jack pads with the rectangle. Many of them have different measurements. Very difficult to find the correct one with a snug fit. If anyone has a recommendation for a specific pad let me know. They all seem a little small and would result in possible slipping.
Old 07-11-2019, 03:27 PM
twh twh is offline
These are the ones I have. I use these or the plywood plugs I talked about.
http://www.reverselogic.us/bmw_jack_...tegory=4591507
Old 07-16-2019, 05:13 PM
These were really cheap and ended up working out really well. They are a perfect fit for the E70 jacking points. No movement. https://www.walmart.com/ip/Rubber-Ja...-BMW/290670126
Old 07-17-2019, 12:09 PM
jiveturky1 jiveturky1 is offline
Mein Auto: 09 335xi 6MT, 05 M3 6MT
That does look like a big discrepancy. Mine are not snug but they're close. I wrapped a little masking tape around it and that extra thickness made it snug enough to stick in there.
