N55 Does it have a common oil leak? - Bimmerfest - BMW Forums
Old 06-15-2020, 06:03 PM
BoringMax BoringMax is offline
Mein Auto:
A dealer told me that the 2012 335i N55 has a common problem with an oil leak near the oil filter flange. Has any body heard of this problem? I ask because my mechanic did an oil change to it and said it has a pretty good engine leak from somewhere top of the engine.
Old 06-15-2020, 08:14 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Valve cover gasket and oil filter housing gasket leaks have been common for more than 20 years. No change from bmw. Ironically all in the name of the environment because of the gasket material.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 06-15-2020, 09:09 PM
dwlink's Avatar
dwlink dwlink is online now
Mein Auto: 435i Gran Coupe
Oil filter housing gasket is a known problem. Very inexpensive DIY, albeit I'd give it a moderate difficult rating. There are many DIY videos out there, but the key take away is having a good quality set of sockets with the right extenders and a universal joint to do the job. Involves loosening up the intake to reach one of the bolts.
If you are not comfortable working on your car, I would not attempt it as it's not a beginner level repair. Tools aside, I think the set of gaskets can be had for $25ish or so. You'll also need a small amount of coolant (figure another $20) to top up the tank as you'll lose a bit when disconnecting the hoses.
If you are comfortable working on your car, but it's your first time doing this job, I'd plan on 2 hours.
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 06-26-2020, 04:12 PM
Mein Auto:
Thanks for the info
Old 06-26-2020, 04:13 PM
Mein Auto:
Thanks for the info guys really helped out
