Freon in 2019 430i - Bimmerfest - BMW Forums
Old 06-23-2020, 09:05 AM
droost droost is offline
Mein Auto: 430
Freon in 2019 430i
Hi, I have a rebuilt F33 missing the hood service details sticker. We are trying to fill up the Freon. Does anyone know how much is the right amount? And if it is 1234yf? Thanks
Old 06-23-2020, 10:08 AM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
Fish around on newtis.info. It's an on-line version of BMW's IETM (Interactive Electronic Technical Manual).
Old 06-23-2020, 12:28 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
From https://www.newtis.info/tisv2/a/en/:
https://www.newtis.info/tisv2/a/en/f...?q=refrigerant
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 06-23-2020, 03:00 PM
Mein Auto: 430
Thank you guys. So, I ended up spending 400 to put the 1234yf Freon in the car and the A/C would turn off as soon in less than a second (hot air blows out). They ran diagnostics and the following codes came up:
FEM -
804363 Refrigerant Pressure Sensor Short Circuit To Ground
Anyone have any experience with this? I'm fearing the sensor is not connected properly. But hard to confirm that.
Old 06-23-2020, 03:12 PM
Could be an internal problem with the sensor, causing a short?
___________
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 06-23-2020, 07:43 PM
Mein Auto: 430
I plugged in ISTA+ and was able to observe the refrigerant pressure sensor hitting a reading of 30 bar which would then shut off the compressor. The cycle kept repeating over and over every 4-6 seconds. Now just trying to learn if this means too much Freon or that the sensor is bad.
Old 06-24-2020, 06:39 PM
rikwynn rikwynn is offline
Mein Auto: 335xi M sport
Refrigerant
You can buy small cans of 1234yf refrigerant at any NAPA store for like $32/can.
FEM -
2015 E80 Z 2.8, triple black, tech package, Style 515 wheels
Old 06-25-2020, 02:21 AM
Michael Schott Michael Schott is offline
Super Moderator
Mein Auto: 2017 VW GTI Sport MT
Are you trying to do this yourself or are you using a quality shop? 1234yf Freon is not something to mess with. Few shops other than dealers have the proper equipment to work with this Freon. The machines are expensive and the demand as of now is low so most shops refer you to a dealer.
Old 06-25-2020, 11:24 AM
Mein Auto: 430
I took it to a repair shop that has the 1234yf machine. They performed a cycle that took about an hour. Drained the system, checked for leaks, and put 1234yf into the system. The issue i'm having is that the compressor turns on, and then turns off intermittently. INSTA shows an error code of 801224 Air Conditioning compressor: shut-down due to excess pressure in refrigerant circuit". I do observe the Refrigerant Pressure sensor hitting 30 bar. with the AC on and about 20 bar with the AC off. The shop knows this is a rebuilt car so they believe they have done all they can in refilling the AC. I'm trying to figure out if AC can be taken out to lower the pressure? if that is possible I can ask them to take some out. Or if I should just have the car taken to a hopefully a better service shop that can sort this out.
Old 06-25-2020, 12:19 PM
CJKaz CJKaz is online now
Mein Auto: 1986 328is, 2016 328iX
They should read both the low side & high side pressures. From there it is standard AC system troubleshooting. Blockage in the high side will cause the high pressure cut out: condenser, crushed tube (front end accident?), expansion device. Switch could also be faulty, the pressure gauges are key to troubleshooting. If over charged (assume they charged it by weight), the pressures will tell the story. If they have that machine, they are likely well versed in AC systems, not a tool for the novice!
