Bleeding brakes on 328i - Bimmerfest - BMW Forums
Old 06-24-2020, 11:00 AM
carlson2005 carlson2005 is offline
Mein Auto: 2015 BMW 328i
I decided to change the brake fluid on my 328i myself, using the Motive brake bleeder from FCP Euro. Everything worked similar to other cars, except the removal of air seem to be very very slow.
I tested and installed the pressure bleeder with about 10 psi of pressure, and then went to the right rear brake to start. When I first opened the bleeder it seemed like I was getting almost nothing out, but after a few minutes it finally started to bleed fluid with very small bubbles, looking like something from a carbonated drink. That went on for several minutes and then finally stopped and I got clear fluid. The left rear brake worked the same. Then I went to the front brakes, which started out with clear fluid right away with no bubbles.
Is there some type of check valve or restriction in the rear brakes that make them bleed more slowly? My BMW repair manual says to use the BMW scan tool and set it to "Bleeding ABS/DSC" before you start pressure bleeding, but does not explain what that does.
Bruce
Old 06-25-2020, 11:32 AM
cleaver cleaver is offline
Mein Auto: 2014 328xiT
Don't know about the Motive method, but I had the same experience with the MityVac vacuum bleeder - rears very slow and not a lot of fluid sucked out, but fronts worked much faster. And yes, I flushed in this order: RR, LR, RF, LF. Incidentally, I had the same experience with my 1997 Mercedes E420.
2014 F31, Alpine White, ED 5/13/14
Old 06-26-2020, 07:52 PM
jparnes1 jparnes1 is offline
Mein Auto: 2011 Z4 35i, 2006 525xi
10 psi is too low. You should be 15-20 ad you'll see the fluid move faster.
2016 340i XDrive, Estoril Blue / Black, 6 MT, M Sport, Track, Lighting, Technology, Driver Assistance Plus, Cold Weather.
2012 Z4 35i, ED 2/24/12, Melbourne Red Metallic, Black leather, 6 MT, ///M Sport, Premium Package, Premium Sound Package, Cold Weather Package, Nav, Comfort Access, LED Angel Eyes, BMWPedals pedal covers, stubby antenna, Luxon strut bar, CF engine cover, LCI side marker, powder coated calipers, Extra Enjoyment Package
Old 06-26-2020, 08:30 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i/F30
Bruce
So you bled the brake lines ignoring the scan tool? Seems like it would work.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
